The last several autocrosses I've done, I've gotten locked out of 2nd gear, while trying to shift from 1st to 2nd and simultaneously going around a left hand turn. Even after completing the turn, I'm still not able to get in 2nd, and moving through the rest of the gears does not help. Eventually (like at the end of a run) I'm able to get it back in 2nd after things "settle" a bit. I've seen some stuff about trying to shift into 2nd either pulling all the way towards the left hand side of the gate and alternatively, allowing a little bit of play to the right, but no improvement.
However, I literally have never had this problem during normal driving. If I want to though, it's pretty easily reproducible by taking a hard left and trying to make the 1-2 shift.
From what I can figure, it's one of three things:
1. Motor (and transmission) mounts (mine are stock, including snub mount, with 111000 miles on them). There is no check engine light for bad engine mounts
2. 2nd gear problem in the transmission
3. A problem with the shifter itself (stock components, never replaced as far as I know).
I'm thinking that since it only happens with changing momentum that it's a driveline stiffness issue, and I'm planning to replace both motor mounts, snub mount and transmission mount. This seems like the most likely culprit to me.
Does this sound like a reasonable place to start before I drop the cash on 4 new mounts? Obviously the only way to know is to do it, but I haven't found the exact issue with confirmation that it was solved by replacing mounts. Would really appreciate input.
TLDR: Read bold
Bonus pic:
