Results 1 to 21 of 21
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    In your unprofessional opinion...
    What am I dealing with here? I got two guess. Oil cooler, and excessive moisture buildup. I've noticed this before, but both times the engine has been cold. I also put a check valve on the end of my crankcase dump upon recommendation from another member. First, I plan on running the engine tomorrow and checking the oil while still warm. If the booger is still on there, guess I'll be dealing with coolant. Unless of course the check valve has something to do with it.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Established Member Two Rings Bruch's Avatar
    Nov 24 2009
    Irwin, PA
    That was on your dipstick? I have seen that in the top end breather tubes on my 2.8 for a long time, with no significant problem other than blow by from 200k plus miles. Never on the dipstick, though.
    I think I would make sure the engine is getting hot enough for enough time on a regular basis to eliminate simple condensation.
    Bruch
    '00 A4 Avant V6 MT
    '01 A4 Q 1.8T Tip
    '95 90 Quattro Sport
    '97 A4 Q 2.8 5 5spd
    '00 A6 2.7T
    '93 90S FWD (junked)
    '88 90Q (sold)
    '90 20v 90Q (sold)
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Yes, off the dipstick and no, the car normally runs about 30 minutes daily, on residential streets. Hardly ever sees oil temp above 150 degrees.
    2000 S4- Working?
    Jun 03 2013
    Sauk Rapids Mn
    I had the same problem. It was because of too much moisture. I think these engines have trouble letting the moisture out especially in cold climate. I reatatched the hose on the back of the valve cover that goes to the pancake valve and the moisture problem went away. I just put a catch can in line to keep the moisture from going to the intake.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Nate01A4 View Post
    So you are saying you needed some vacuum to draw the moisture out? I have no pcv system, just the tube.
    Hopefully this is the last winter I run this car. I'm looking to pick up a beater this summer and park the a4 during the winter
    2000 S4- Working?
    Jun 03 2013
    Sauk Rapids Mn
    thats what ive notice with mine. especially I also only drive about 20 minutes to get to work so it would nevr realy get hot. durring the summer I never had a problem. They sell cheap vacuume pumps I was thinking to stick one in there and see if it would help. but thats next winter my ride is still down!
    Nov 24 2009
    Irwin, PA
    Some food for thought. Back in the old days of V8s, pre-ECUs, one way to keep a decent vacuum in the crankcase without routing the fumes back into the intake manifold was this:
    Drill a 3/4" hole in the collector of each header, weld in a piece of 3/4" pipe about 4" long, at a 45 degree angle. This pipe would draw vacuum being in the exhaust stream-Venturi effect I think it's called. You put a check valve on it, and ran a hose up to each valve cover.
    Maybe you could route a line from the top of your catch can like that? Maybe someone has tried that, not sure how it would work with forced induction.
    Bruch
    '00 A4 Avant V6 MT
    '01 A4 Q 1.8T Tip
    '97 A4 Q 2.8 5 5spd
    '00 A6 2.7T
    '88 90Q (sold)
    '90 20v 90Q (sold)
    Jun 03 2013
    Sauk Rapids Mn
    this is the pump I was going to try. I was thinking to just run a toggle switch at first and if it worked then maybe connect it to a thermo switch so that it would only run when needed. I dont know. I just thought its cheap enough to try. http://www.ebay.com/itm/DC-12V-50Kpa...item27d7b45615
    Veteran Member Three Rings catbed's Avatar
    May 22 2011
    South Jersey
    Seems like moisture build up if you don't get it over 150*. Get that bitch's oil temp up to 212* at least to vaporize it.
    01 A4 Avant <- TwinScroll T3 jawns
    Built 06A|Built AEB|RR Stg3 Clutch|01E 6MT|60 Trim|1000cc EV14s|Bad MAF|Clunking Suspension|Cracked Dump tube
    NefMoto Tuned
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Bruch View Post
    I do not have a catch can, just a dump tube. But I like your idea, and it has been done before. That way the exhuast just burns all the junk up
    2000 S4- Working?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by catbed View Post
    I'd say at least once or twice a week it gets that high. Hopefully it warms up soon so it will get that hot on my drive to school
    2000 S4- Working?
    Mar 17 2014
    2000 gmc sierra
    Ontario Canada
    It's because you don't drive it hot enough it's moisture in the oil to much city driving not enough long drives I'd change oil go for long few hour drive and change it again (just me)
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Blown head gasket or cracked block. One of the two.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Dec 05 2007
    Professional opinion, someone took a sh*t in your engine though the oil fill access. Find out who did it, and pay back the favor by taking a dump in his engine. Fair is fair!
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Avant Nate View Post
    Slippery slope my friend. No, the enigne was rebuilt 7k ago
    I drove around a bunch today. Checked the oil right after it shut off, and there was no goo on the stick. Just checked it after an hour or two of cooling down and this is what I found. I am kinda torn and don't want to assume it is an oil cooler, especially since there is no obvious oil in the resevoir.
    2000 S4- Working?
    Mar 17 2014
    2000 gmc sierra
    Ontario Canada
    Coolant will overfill the oil
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Drifter420 View Post
    Oil level is dandy. Disregard what the stick looks like
    2000 S4- Working?
    Dec 23 2009
    Boulder, CO
    Quote Originally Posted by redline380 View Post
    Slippery slope my friend. ]
    I was just kidding, forgot to use sarcasm font.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Figured you were. Thats why I said you were on a slippery slope. I think I remember only one confirmed bad head gasket on the forums. And we did have a brutal winter up here temperature-wise, but I dont run straight water.
    2000 S4- Working?
    Veteran Member Four Rings thenj3's Avatar
    Dec 25 2009
    North Jersey
    To me that looks like moisture. My catch can always looked similar during the winter. I wouldn't be worried. It appears very runny where if it was coolant mixing you have a more solid substance. Does it have any type of coolant smell at all?
    2001 2.0l ct-5858 parting out- ringer racing, full race, comp turbo, maestro
    BUY MY STUFF: http://www.audizine.com/classifieds/...partout&cat=20
    http://www.audizine.com/classifieds/...-skirts&cat=54
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by thenj3 View Post
    Not much of a smell, and like I said no oil in the coolant and the coolant level has stayed the same. I think it is just moisture too.
    I went out to check again a half hour ago and there were only small streaks on the dipstick, which leads me to believe it isn't very much, whatever it is. I think i'll go check my turbo for shaft play just incase
    2000 S4- Working?
