Results 1 to 15 of 15
    Feb 10 2014
    Palm Beach Gardens, FL
    Trick to aligning snub mount?
    I jsut installed my 034 snub mount and cant seem to get the sucker on,. I searched for little tips to do this but cant find any. I realigned the plate it mounts too but the mount wont slide all the way on, is it safe to trim the isnide of the mount? I tried dish soap and i though i got it all on but then popped out under a test drive, Ill be cracking at it again tomorrow.
    Senior Member Three Rings usmc.S4's Avatar
    Jun 20 2011
    Copious amounts of physical force.
    Feb 18 2013
    Silicon Valley, CA
    Quote Originally Posted by usmc.S4 View Post
    After the addition of copious amounts of WD-40 (or equivalent) to both the mount mount and the inside of the rubber bushing.
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    I've heard it's a real whore from several people, even on the repeat.
    never tried it, but: I'd try prybar from a buddy at an angle and a very blunt punch (rag covered probably) with a hammer. then I guess prybar/blunt hooktool from a buddy to pull it over the nubbin on the motor, probably while using your hand as well.
    Feb 10 2014
    If it helps, Im leaving the entire rad support on the car. I think Im going to try to trim a touch more off the inside and then boil it and the pry bar trick. Thanks for the tips guys.
    Jun 20 2011
    I bought the ECS snub mount. Fits like a glove. But yea. Try trimming it. Not too much though. You can always trim more, but you can't put it back lol.
    May 20 2012
    San Jose
    Getting the poly bushing on the motor mount was kind of a PITA, but the cage goes right over it, no trimming required. Leave the four bolts holding the cage to the lock carrier loose until the lock carrier is bolted tight, then tighten the snub cage.
    Mercedes silicone paste helps get the bushing on the engine mount. Try bar soap. Don't use hydrocarbons.
    Aug 05 2011
    Memphis, TN for now!
    Quote Originally Posted by Junkyardspecial View Post
    If you used soap and air was trapped behind the snub then it'll pop itself back off. I would take the snub and mount off the car and use a press/vice to get it on. I would also let the soap dry up.
    Veteran Member Three Rings nkbks4's Avatar
    Mar 26 2009
    Silver stg 1 avant, Black 01' STG 3, wife - Honda Pilot
    Naples, FL.
    Boil some water and soak snub for 5-7 mins then run out and slap it on... I had to boil mine twice, FYI.
    If it's not sliding into the cage itself, then u will have to trim as stated on their website.
    Feb 10 2014
    Its on! I removed the intake inlet to add some extra maneuverability to the rad support. I boiled once, trimmed a touch more on the inner ring, and then doused both the mount and the bushing in wd. It literally popped on with a pop noise. Car feels sooo much more crisp between shifts. now i need to see how much clutch abuse i can give her! Thanks for the help again. Oh copious amounts of physical force were needed too.
    Senior Member Two Rings Ryanic's Avatar
    Jun 03 2013
    Minnesota
    Should have went with ECS, like usmc said, It fit like a glove. Super easy to get it on. But I'm glad you figured yours out!
    May 16 2008
    WA
    May have just been bad luck. I installed the 034 Snub and Cage a year or more ago with just a little heat and a little might. No trimming was needed in my case. It fit extremely snug, and I have zero concerns that it would pop loose or wiggle free as a result.
    Feb 17 2014
    Pensacola FL
    no issues with mine except with the cage mounting plate. whomever it was that removed it and reinstalled it last, cross threaded and destroyed one of the bolts so I need a new mounting plate. Used a press to put the bushing on the actual mount.
    Veteran Member Three Rings Jmills's Avatar
    Jun 20 2012
    Rubber Mallet and WD-40, took me less than 5 minutes that way.
    '00 Hibiscus Red Pearl B5 S4 203k on stock k03s! MTM Stage 2...273 AWHP 344WTQ - SOLD Sadly
    2006 Tarmac Black Evo IX 325whp 310 wtq - Daily while I figure out the next Audi
    The Other FB group, the SFW English speaking one, 10,000+ Members
