Results 1 to 40 of 43
    Account Terminated Two Rings
    Mar 20 2014
    I want to take my stock A4 to 400HP, have $6000 at hand for upgrade. Need suggestions
    I've checked APR, but their turbo stage 3 system offers 375 horsepower, so I'm wondering is there anything stronger than that. I mean I don't see APR offering anything higher than stage 3 @ 375HP.
    I am pretty new to tuning, so I need more information. Any more powerful turbo kits out there?
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    It really depends how much $$ you want to spend. Frankenturbo F23L is the best deal for around $2000-$2500 all-in, and can get you 300whp, which is roughly 375-400 at the crank.
    Otherwise you'll have to go with a big turbo variant. Something like this GTX28 kit from RAI. Some people haven't had the best experience with RAI, but they are in Baltimore.
    http://www.raimotorsport.com/RAI-B7A...4_2.0t_gtx.htm
    Another option is the 2.7T swap with K04/RS6 turbos. Becoming more common and you can do it for around $6000. You can easily make a reliable 450whp with that setup, or do rods for an extra $500 and make 550+.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Mar 20 2014
    Quote Originally Posted by LINDW4LL View Post
    You could do a Stage 3 2.7 swap for about that. It really depends how much $$ you want to spend. Frankenturbo F23L can get you 300whp, which is roughly 375-400 at the crank.
    Forgive my ignorance, but what exactly is a swap? Are you saying replacing my 2.0 engine with a 2.7 engine?
    Also, another stupid question.
    Can the APR 3 Stage 3 turbo kit be upgraded further? Are turbo kits upgrade-able?
    I understand that Stage 3 runs the GT2871R but instead of the GT2871R can I get it with GTX2867R instead?
    Dec 10 2011
    CLT | MKE
    I edited my post for clarity. However, yes that's one option- but it's much more work.
    -Hayden
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    save up about twice as much
    do NOT go to RAI unless you want your car back with stripped holes and missing bolts, a manifold and downpipe that don't fit... that's just the beginning. not until i completely tore down my motor and put it back together was i able to fix all the idiotic damage they did, not counting of course the complete engine failure requiring an extensive/expensive rebuild that happened 1200 miles after i got the car back, because they didn't even do research / look to replace a part that has failed in multiple 2.0T's under their care (not their fault that it blew up, but they knew it was an issue, had dealt with it before, and didn't care). i just recently got them to take my build off their site. i got the car back with major oil leak, siphoning w/m because ray "swore" he put a solenoid in which they didn't, i could literally go on for days about the amount of fuckups they performed
    when i picked up my car there was a customer who picked up his car, drove about 5 minutes and lost all brakes b/c they left the brake lines on the exhaust manifold......................... he had a rear Brembo BBK installed by them, so no e-brake.
    he barely survived that one. assholes!
    Veteran Member Four Rings glissoar's Avatar
    Oct 16 2010
    2010 Jk Unlimited
    virginia beach
    as Drumnjuny said, for 6k on our motor your not going to get 400 WHP, CHP yes but not real usable power. Save your money a little longer
    2008 A4 *For Sale*
    CTS K04, United Motorsports Tune, Brute Rods, CP pistons, 9:1 compression, Autotech Fuel pump rebuild, ARP head and main bolts, RS4 injectors, Custom built FMIC, 034 cat (gutted), AWE Exhaust, Stasis SS Coilovers, Stack boost gauge, Hydrographic dip trim, Ti Front Grill
    Veteran Member Four Rings ericpaulyoung's Avatar
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    For about 20k you can do rods, pistons, fresh head, exhaust, fueling, extra injector, extra controllers, and sequential turbos. At least if you do all the work yourself. Add 10k if you pay someone to do it. But that should get you up to 400 awhp with raging power everywhere. You can find the info you need on the diesel websites and supra forums. I should have mine up and running this year too. So after I get all the particulars worked out it should be easier to copy my setup without buying a bunch of parts you won't need after finalizing the kit.
    EPY
    Epy
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    For 6k you should just drop in rods, add exhaust, a franken turbo, and S3 injectors. That is easily your best deal for usable power.
    Epy
    Oct 16 2010
    2010 Jk Unlimited
    virginia beach
    Quote Originally Posted by ericpaulyoung View Post
    This!
    2008 A4 *For Sale*
    Veteran Member Three Rings mightemouce's Avatar
    Mar 12 2007
    01 S4
    That ^ if you only want to spend 6K
    07 - RS4
    05.5 - 2.7t B7 -Sold
    Insta-Ste3v3_0
    Nov 15 2011
    Montreal | I sell in USD
    X3, for your budget that would be the best option.
    And yes as mentionned by Drumnjuny, stay away from RAI.
    *****I sell in USD*****
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    YUP! i wish i had stayed with a k04-frame turbo, the car is way more fun and drivable, plus less issues....
    Veteran Member Four Rings Inked's Avatar
    Dec 11 2010
    Polaris Outlaw 525 Quad
    Central FL
    Just go stage 3 and be happy....
    (there's always someone faster, no matter how fast you are)
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by drumnjuny View Post
    Yep. That's exactly were I'm staying
    Veteran Member Four Rings xander3zero's Avatar
    May 30 2013
    Rhode Island
    Quote Originally Posted by Inked View Post
    Even if he decided to go Apr stage 3 the kit itself is 6k so if he's not doing it himself that won't be within budget
    Sent from my Nexus 7 using Tapatalk
    2017 Audi S3
    Mythos Black Metallic | Dynamic Package | Tech Package | S Sport Seats | Bang & Olufsen
    Previous:
    2013 Allroad Premium+
    2006 A4 Quattro 6MT
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    buy a bike for 6k and smoke a couple lambo's
    Veteran Member Four Rings jsandor91's Avatar
    Jun 10 2011
    dead hookers
    South Jersey
    like others have said if you want 400 chp is possible but the stock rods can't support much more then that.
    either go with a franken turbo or a stock location kit from atp. for fmic and exhaust go either custom or the cheap as possible. a $1200 fmic kit is not necessarily better then a $600 kit etc.
    Quartz Grey B7 A4 Quattro 6MT
    Maestro + Epy Tuned / GTX2867r / S3's / Spintech Non-Resonated 3 Inch Exhaust / Cold Side Synapse DV / TR18 + 2.5" Piping / Hpfp S1 Pump
    Bi-Xenon retrofit + Fly's leds / ST Coils + Rsb / 18x9.5 Miro 111's
    Dat Der Build Thread
    Coming Soon: Boost Manager +, Drakes Performance Stage V Clutch
    Nov 13 2011
    b7 s4 avant
    buy a turbine and some ratcheting straps and put it on your roof. Or, small solid fuel rocket boosters. Turbos are played out son!!!
    if not viable, shoehorn second motor into trunk. I saw it done on a tiburon street racer.
    I drive a truck now.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Quote Originally Posted by eliteplague View Post
    Before I even read this thread; are you fucking kidding me? This question can only mean that you did zero research at all, and have never read a single thread on this forum. Come on.
    I will now read the thread.
    Edit - I can't believe everyone was nice about this one. Lol. It must be your lucky day.
    Sent from my SGH-M919 using Tapatalk
    2021 Audi S4, P34 Intake
    Jun 10 2011
    dead hookers
    South Jersey
    We were feeling nice today maybe?
    Pull your turbo out... Weight reduction FTW!
    Sent from my Nexus 4 using Tapatalk
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    DMV Area
    Agree 100% + upgraded intercooler. Even if you don't reach 400CHP you should be close and that will bring you lots of fun avoiding a lot of headaches.
    - Chip
    034 Stage 2 ECU | 034 Stage 2 TCU | Wagner IC | IE Downpipe | ECS CAI Intake | Fuel-it e85 | Mishimoto Catch Can
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    HP is for chumps. It is all about KW now.
    Jul 26 2009
    DMV Area
    Quote Originally Posted by Jake@JHM View Post
    Lol
    On a serious note the power and torque curve it's more important than peak
    - Chip
    Aug 31 2011
    Lathrop
    Quote Originally Posted by shiro1745 View Post
    Lol
    True, but I think both 0-60 and 60-130 times together and 0ft-1320ft are even better =]
    Veteran Member Four Rings LoKisSpYdR's Avatar
    Jun 26 2012
    Brilliant Red B7 A4 2.0T Titanium quattro Tip - 2015 Q7 PP
    Reading, PA Area
    I heard JHM's stage 1 will make 450 awhp.
    But until it's released, we'll never know
    B6 A4 1.8T Dolphin Gray qM
    4L Q7 3.0T Glacier White PP
    Aug 31 2011
    Lathrop
    Quote Originally Posted by LoKisSpYdR View Post
    Weird, I heard that too! However, it wasn't AWHP. It was strictly the Front right wheel and back left wheel. 450 FRBLWHP
    Jun 26 2012
    Reading, PA Area
    Literally spit water.
    Nice
    Aug 31 2011
    Lathrop
    Nice
    Hehe our tuning is a little wacky, what can I say!
    Senior Member Four Rings A410's Avatar
    Feb 29 2012
    2004 Pontiac GTO
    Baltimore, MD
    I will also add that I haven't had the greatest experiences with RAI either of the times I have dealt with them and I know a half dozen other b7 owners around me who have been screwed as well. I would recommend NGP (New German Performance) up in Aberdeen to do all and any work on your Audi. Trust me lol
    2008 A4 2.0T Quattro / 3M Matte Orange Vinyl Wrap / APR Stage II+/ APR HPFP / RAI TP / RAI Catch Can / Custom RAI Exhaust / TR-11 FMIC / 034 Motorsports TIH / K&N / AudiUp Race Snub / 640 Mod / Various VAG Mods / New South Boost Gauge / R8 Coilpacks / NGK BKR7E / 200+ Lbs Weight Reduction / 19" RS3s / RS4 Rear Sway Bar / Coilovers / Cupra Lip / LED Taillights / 20% Tint /
    Veteran Member Three Rings swaggerwagon's Avatar
    Sep 28 2012
    NC
    You guys are awfully nice to the OP.
    Questions like these -____-
    Anyways, my personal opinion: Get a cool air intake, a NOS fogger system, and a T4 turbo.
    B8.5 3.0T/ B5.5 1.8T
    Jul 26 2009
    DMV Area
    Oh and my experience with RAI sucked
    - Chip
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    You can pull off a 6k build, but you will do the work. Rods, S3 injectors, exhaust, ebay FMIC, Frankenturbo, and a tune. You will have a very fun car.
    epy
    Epy
    Aug 31 2011
    Lathrop
    We have a nice FMIC that set at a great price =D
    Veteran Member Three Rings abzoni's Avatar
    Nov 13 2010
    buy an old civic, build engine with big ass turbo and you'll probably still have money left over lol
    but seriously, having experienced stage 3...like others have said you need more than 6k. I started about the same as you...planning to spend 6k, ended up more than doubling that. 400chp is easily done with 6k though, 400awhp is the tough one.
    GT3071R, built motor, complete fueling system upgrade etc etc.
    Dec 11 2010
    Central FL
    Lol
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    i lol'd also.
    we should not be so nice to this guy... let him in on our ways. in that spirit.... 6k is perfect for this plan: (1) buy AR-15 and 100000 rounds (2) shoot self in face (3) ??? (4) PROFIT!!!!!
    Mar 24 2013
    Oakdale, CT
    What are the other 99,999 rounds for? And what would someone in CT do in thos case? Convieniently, I have 3 AR-15s already, so I'm closer to profiting.
    -Adam
    Jun 26 2012
    Reading, PA Area
    Ssshhhhhh! They're listening!
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by abzoni View Post
    Agree. If the OP want a track car. See the # he wants. A dune up civic would be best spent $$$$. For 6K he'd get that off.
    Senior Member Two Rings _muppet_'s Avatar
    Mar 22 2009
    Clarion PA
    I also agree, maybe not a civic specifically, although the bang for buck is certainly there. B5's have come down in price a lot over the last few years, you could buy a decent stage 2 s4 for 6k, or a beat up stage 3, or a vr6 turbo vw in whatever platform you fancy. I just have not seen any b7 that makes me feel like it would be a worthwhile venture to drop that kind of money into the motor.
