Protuning Headlights: Sorry, don't have any with the LED's on, don't know what I did with em.
Anyways, I finally decided to just buy a broken a5 light and see how the professionals did it.
Baked it and took the lens off and discovered that it's just three super bright LED's shooting through some light tubes.
One single:
and one double: (that I unfortunately broke when I removed)
two of the tubes close up:
So clearly that whole array won't fit in a B7 headlight, no matter what. So just to prove my concept to myself, I took the long Tube out, hooked it up to the single LED, and e-taped it to the silver inlay. It's actually not far off for size, though the LED and heat sink would either be right where the turn signal is, or extend outside the housing. Probably flip the whole thing and put the LED and heat sink where the high beam was, or behind the high beam.
Tube off:
Tube ON:
Stupid bright running off a 12v AA battery pack. Stupid bright.
This is also without the black strip that is supposed to go behind the tube.
And that's as far as I have gotten tonight. But I like where it is going. The only thing is that if I were to follow the inlay with the tubes, I think it would look too much like a Lexus. My goal is to create a look that is Audi without being a rippoff of a newer model. More like a homage.
Am I crazy? What do you think? Anyone willing to try? The a5 headlight was $100 (broken housing)
