Originally Posted by
Slow4
^^ have you checked your oil level?
Remember when you took the valley pan gasket out AND oil filter housing out, you can lose a good amount of oil.
Run through these set of questions:
Are the check valves firmly pushed in till click or pop?
Is the nozzle firmly in place?
Is the gasket sitting flush and proper?
Are the 16 bolts on valley pan torqued to spec?
Are the knock sensors torqued to spec?
Are the 12 bolts on IM torqued to spec?
That's all I have for now but ya, mental checks and if need be, go back and double check everything.
EDiT:
I went back and re-read your posts.
You did this DIY AND piggies?
Did you start the car in service position after you finished the DIY?
Thanks for the reply and the questions, Slow4.
Oil level is full, I had to add about 1/2 qt. after the job. The answers to your other questions are "yes", but the logical explanation is that I didn't get the valves or oil jet pushed in far enough. But, I do remember distinctly making sure that I pushed them down firmly until they wouldn't go anymore. The frustrating thing about this, is that I had another "reduced power and misfires on multiple cylinders" just before I performed this job. So now, I don't know if the light is related the the misfires & reduced power, or the oil valve job.
I did not do piggies yet, because after the oil valve job, I started the engine, warmed it up, then performed the catalyst check on both cats within VCDS. Both passed. Incidentally, when I first fired up the engine after the job, while it was still in service position, the oil pressure light came on for maybe two seconds, then went off. But after reassembly and rolling out for the test drive, the light came on and stayed on. I decided the smart thing to do was to park it and not ignore it.
Could a plugged pre-cat still allow a cat test in VCDS to pass? I've got the whole next week off from work, so I've got some time to really try to figure this out. Here's my game plan as of now:
- Recheck the oil valve job.
- Check the oil pressure with my HF oil pressure gauge.
- Perform a compression test(I hope there is a DIY on how to do this, as I've no clue).
The engine is down on power, and runs normally, except that it's louder than normal when under acceleration. No codes as of now, but then again I cleared them right before the oil valve job, and probably have less than a 1/4 mile on the engine since then.
Does my plan sound good to you?
