Results 1 to 10 of 10
    Oct 15 2006
    From a few to one...
    Arlington, VA
    Misfires on one cylinder bank (CYL 1, 2 & 3) on 3.0 V6
    So I've been running into an issue where I get random misfires on only cylinders 1, 2 and 3 while revving through the engine. The misfires only start above 6k RPMs, right at the top of the range. I can reproduce it every single time. I've tried swapping around plugs and coil packs, no luck.
    I didn't do the timing belt myself, is there any chance the notch might be off on that bank? If so, how would I go about checking that? I don't have too much experience working on the 3.0, so kind of getting acquainted to it all. Also, I can't seem to get above 19mpg on the 3.0. This includes babying it to squeeze as much as possible out, still only getting 19mpg. Could this be related to the timing being off?
    The codes I get are P0300, P0301, P0302 and P0303. Also getting a P0431, but not sure if that's related or not.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - APR Stage 1 ECU/TCU, APR Intake
    Feb 22 2012
    05 A4 1.8tQ, 98 GTI VR6
    Burnsville, MN
    so you swap coils to cylinders that are not misfiring and clearing the faults after and they still come back for cylinders 1, 2, and 3?
    Senior Member Three Rings Blockis's Avatar
    Jul 25 2012
    2007 A4, 2011 Q5
    Boston, MA
    Yeah, are you clearing the codes after you swap them? I find this awfully interesting actually.
    P0431: Warm Up Catalyst; Bank 2: Efficiency Below Threshold - don't think it's related.
    Paul
    2002 A4 1.8T Quattro | 197k ☠️
    2007 A4 2.0T Quattro | 168k
    2011 Q5 2.0T Quattro | 240k 🔧
    Veteran Member Four Rings RENOxDECEPTION's Avatar
    Nov 04 2012
    2000 B5 A4 1.8TQM, 2000 B5 A4 1.8TQM
    Reno
    Quote Originally Posted by NyteEscape View Post
    Cylinders 1 2 and 3 are not on only one bank if I'm not mistaken.
    2000 Audi A4 B5 1.8TQM AEB/06A
    1998 Audi A4 B5 4.2QM (Thread)
    2000 Audi A4 B5 1.8TQM K24 Turbo, AEB Wideband
    Oct 15 2006
    Arlington, VA
    Quote Originally Posted by MrTurrtle View Post
    Yup, swapped the coils and plugs around, misfires are staying on 1, 2 and 3.
    Quote Originally Posted by Blockis View Post
    Yup, cleared the codes after the swap.
    Quote Originally Posted by RENOxDECEPTION View Post
    Maybe I'm mistaken then. I thought the layout was:
    ---FIREWALL ---
    (3)---(6)
    (2)---(5)
    (1)---(4)
    --- RADIATOR ---
    If that's not the correct order, I'm even more confused as to why it's consistently 1, 2 and 3 if they're not even on the same bank.
    Oct 15 2006
    Arlington, VA
    so some late night googling has led me to bent valves (http://www.audiforums.com/forum/audi...firing-132820/). Not sure of the relevance, but not looking forward to finding out if that's the actual issue.
    Feb 22 2012
    Burnsville, MN
    if they are on the same bank, i would check the cam adjuster. could not be adjusting, not getting enough oil, stuck, watever. each bank has its own adjuster on a v6.
    Nov 04 2012
    Reno
    Guess I was wrong
    Sep 03 2009
    San Antonio, TX
    Before going through all that, I would first check the coil harness for broken/shorting wires. I know on the 1.8ts that is an occur acne more frequent than some may assume.
    MY BUILD
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Check the harness first for any bad wires. After that, my guess would be bad cams, and then it would be timing/valves for option 3. Option 1 of checking the wires would be the easiest method, and probably the cheapest to fix. After that, it just goes downhill. You're correct that 1-3 are on the passenger side and 4-6 are on the driver's side as well for the cylinder order.
