Results 1 to 36 of 36
    Mar 28 2009
    Minneapolis, MN
    iPhone 5 Setup in my B8.5 S4
    Because it came up in another thread, I figured I will post my iPhone 5 mount in its own thread as well so it can be easily linked back to it later since the topic comes up every once in a while. This setup has been built through a lot of trial and error to find the right combination of cables and adapters. I have used it in my B8.5 S4 for over a year, and earlier versions in my B8 S4 and B8 A4 Avant. If you have questions, they might already be answered here, but feel free to ask. This setup is specific to the iPhone 5/5S, but simple adjustments can be made with items like the cradle or cabling to adapt it to your particular device.
    My mount is a PanaVise 75102-109. Also on Amazon: http://is.gd/HWNaBF
    My cradle is a ProClip 514433, "Padded Holder with Tilt Swivel for Cable Attachment for Apple iPhone 5." I use this cradle because it allows me to keep the cable always connected in the dock so all I have to do is drop my iPhone in and go.
    I'm using this iTeck female-to-male 30-pin extension cable plugged into the AMI port in the glovebox for constant power and hardwired audio:
    That extension cable plugs into an Apple 30-pin to Lightning adapter cable:
    Two important things to note:
    • Not all iPhone/iPod extension cables are equal. Some will only charge an iOS device, but not send audio. After some trial and error, I found that the iTeck cable does both.
    • The Lightning adapter cable and the standard Lightning cable that comes with the iPhone 5 have slightly different Lightning plugs (seen below), and ProClip makes specific cradles for each.
    Standard USB-to-Lightning cable on the left; 30-pin to Lightning adapter cable on the right.
    The cable routing goes:
    AMI port --> OE Audi 30-pin iPod adapter --> iTeck 30-pin to 30-pin extension cable --> Apple 30-pin to Lightning adapter (the long one, not the little plastic adapter) --> ProClip mount*.
    *That mount is specifically for the Apple adapter I'm using. If you use a different cable or have a different phone, you will need a different ProClip mount, obviously.
    Currently, the extension cable runs along the back of the glovebox and out the back left corner of the glovebox door. From there it goes inside the center stack, and then exits next to the climate controls. If you have a set of radio removal tools, it's very easy to get into the center stack to route the cable. The cable is only visible for about 4 inches, and since its black, it blends in well. You can't see the cable where it exits the glovebox because it's so far back. I may someday route the cable behind the glovebox if I'm feeling ambitious, but it's very low on my list.
    This setup works perfectly. I plastidipped the cable of the Apple adapter black so it doesn't stand out in my interior. You want to use the real Apple cable because the cheap adapters don't work. I can add a pic later if anyone's interested. This is with an iPhone 5 running iOS 6 and now iOS 7. No issues with either OS. Bluetooth call audio still works great as well.
    This is the PanaVise mount for the B8: http://www.panavise.com/pages_addons...artn=75102-109
    It comes in two pieces.
    One you attach to the car behind/next to the center vents:
    The first piece is mounted in the visible screw hole behind the center vent, which you can see here:
    And the other piece screws onto the first piece:
    The final mount looks like this when installed before attaching the ProClip cradle:
    Here is the finished mount:
    When I get into my car, I drop my iPhone into the mount and go. This particular ProClip is designed for iPhones without a case, but you can get a ProClip that is compatible with cases. I prefer not to use a case, so this is perfect for me. I went through a few different combinations of cables and adapters before this one. I've been using it in my current S4 for over a year now and have had no issues.
    A couple questions I've gotten about this setup:
    Q: Why do you use the 30-pin to Lightning adapter if you have an iPhone 5?
    A: Because I originally put this setup together when I had an iPhone 4 with the 30-pin connector. Since I knew it worked, I didn't want to change too much. Using the Audi 30-pin AMI connector also lets the car know that it's an iOS device connected to it.
    Q: What if I use Audi's USB adapter in the AMI port and a standard Apple (or otherwise Apple-certified) Lightning cable and no 30-pin adapter?
    A: That may work to charge the phone, but I don't believe that the MMI will recognize the device as an iOS device. This would probably still work since you could use bluetooth for streaming audio. This would require a different ProClip mount, since the one I use is specifically for the adapter I have.
    • The longest Apple-certified Lightning cable that I am aware of is the 6-foot Amazon Basics Lightning cable. I have a couple of these at home and they work great. If you try this (or any cable) with the Audi USB adapter in the AMI port, please let me know your results.
    • There is a new Audi Lightning adapter for the AMI port, but as far as I know, there are no Lightning extension cables yet.
    Q: Does the phone go right onto the charger pretty well or do you have to position it?
    A: The great thing about the ProClip cradle is that they are designed specifically for the phone you have. The iPhone 5 slides into the grooves on the ProClip, which places it perfectly on top of the connector every time. This mount would also for the iPhone 5S since it has the same form factor as the 5. It probably would not work for the iPhone 5C because the 5C is slightly thicker, but I do not have one to test it with. It may work but could be a bit snug. When I get a new phone, I will upgrade the cradle accordingly.
    Any other questions, feel free to ask.
    Veteran Member Four Rings Dannydyn's Avatar
    Dec 20 2013
    Mercedes Benz ML350
    Could be a good idea to put a thread together with different setups....
    My semi-hard wired setup…. Since I'm constantly on the look for work emails, I needed a spot to mount the phone in front of my face so I don't have to take my eyes off the road every time an email popps. I also use my phone for Escort Live! and Waze, so that's another reason, I needed it at eye-level.
    I bought a long lightening cable, plugged it to the lighter socket in the armrest, routed it under the console, under the steering wheel bottom cover, through the fuse box, and up the A-pillar to finish off by my cradle. For a cradle, I have this one: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    2014 S4 | 6MT | Estoril Blue | Lunar Alcantara | Rotors
    AWE S-Flo | Bilstein B8 | H&R OE Sport | RS4 Grille | 35% Tint
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by Dannydyn View Post
    Excellent idea.
    How long is the Lightning cable you have? Link?
    Veteran Member Four Rings achilleas101's Avatar
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    can you rename the thread to "smartphone" setup. i have a samsung S4.
    here's my setup. I don't have Nav, therefore no bluetooth streaming, so the cable there connects into the audi interface in the glovebox. The suction cup mount is perfect to fit in the ledge in front of the screen there. only the very right of the screen is blocked. nothing that bothers me.
    i used this bracketron bracket. The arm is flexible so i just bent it a bit to fit in front of the hazard light button.
    i have the cable running down the center console, held by little hooks on self adhesive pads
    i drilled a hole under the glovebox and fished the cable through. i needed a 3.5mm extension cable from the audi interface cable. i had one laying around that was 20' long, so hence the need to coil it up.
    Gone but not forgotten:
    2013 S4 Imola Yellow | Black leather/Silver Alcantara | 6MT | B&O | Sport Diff | Silver 19x8.5 Avant Garde m550 | XPel Ultimate full hood/fenders | Eurocode SS
    2003 A4 3.0 6MT;
    1998 Acura Integra GSR 5spd
    Gone and most likely in a junk yard somewhere: 1990 Toyota Tercel
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by achilleas101 View Post
    I can't edit the thread title, but if a mod wants to, that's fine with me. I titled it as my iPhone 5 setup so that it would come up for people searching, but if more people want to post their setups, I'm totally fine with it becoming a compendium thread for various solutions.
    Dec 23 2013
    OP - did you drill a hole in the glovebox? Can you take a photo of where the cable passes through the glovebox to the center dash? TIA!
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by ahc View Post
    No, it runs out of the rear corner of the door and right into the back of the center stack.
    I may pull the glovebox out someday and route the cable behind it, but that's pretty low on my priorities. Running the cable this way does not impede opening the glovebox at all, and you can't see the cable if you stuff it down all the way. It doesn't bother me, but I don't reach into my glovebox very often.
    Apr 15 2009
    PA
    Great write up. I just bought the Lightning to 30-pin adapter from the Apple store. I have the OE AMI (30 pin) adapter in the glove box. However, when I connect my iPhone 5s, it says "accessory" not supported on the phone and MMI says "No device connected". It does charge, but no MMI connectivity. Car is a B8. What am I missing? OP, didn't you say you tried this in both B8 S4 and A4? Does the B8 MMI not support iPhone 5s?
    2019 Audi RS5.
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by JJDubya View Post
    First off, the B8 doesn't have native bluetooth audio streaming, so you'll need a different solution for that. A lot of B8 folks are using the ViseeO Tune2Air adapter for audio streaming.
    I used a very similar setup in my B8 S4, but I had an iPhone 4 with the 30-pin connector at the time and didn't have any issues with it. I added the Lightning adapter in my B8 A4 Avant when I got my iPhone 5. I don't have an iPhone 5s to test with, but it should work the same way.
    When you plug your phone in, what setting are you on in the MMI? You will need to change your source to iPod if you haven't. Do you have navigation in your car?
    Apr 15 2009
    PA
    Understood about Bluetooth. I have nav in the car. I would expect 5 and 5s to work identically, so agree if your B8 Avant worked with the 5, the B8 S4 should work with the 5s.
    When I plug in, I hit "Media" on the console then "Source" via the top right MMI button. That's where it says "AMI No device connected".
    2019 Audi RS5.
    Apr 15 2009
    PA
    I remembered I had an ancient iPod in the house. I plug that in (without the Lightning adapter of course) and it shows right up on the MMI. Its definitely something with the adapter or iOS 7 on the 5s?
    2019 Audi RS5.
    Mar 28 2009
    Minneapolis, MN
    It does sound like an iPhone issue. I guess I'd make sure the phone is up to date on iOS. If you don't have any music in the library on your phone, that can cause the MMI to get confused too. Anybody else with an iPhone 5 or 5s that you can try in your car to see if it works?
    Apr 15 2009
    PA
    I'm wondering if the problem is actually the fact that the phone is up-to-date (7.1 presently). I have a feeling one of the recent iOS updates broke functionality.
    Can anyone else confirm they are on the latest version of iOS and using their iPhone 5s with the pre-facelift MMI (B8) w/ nav using a 30-pin to lightning adapter or cable?
    Mar 28 2009
    Minneapolis, MN
    Bumping this because of a planned update:
    ProClip has announced new cradles for the iPhone 6 & 6 Plus:
    iPhone 6 without a case:
    http://www.proclipusa.com/phone-hold...ut-a-case.cmsv
    iPhone 6 with a case:
    http://www.proclipusa.com/phone-hold...th-a-case.cmsv
    iPhone 6 Plus without a case:
    iPhone 6 Plus with a case:
    The cool thing about these is that now you can order them with a hardwire power cord, making install a breeze. I'll probably go the route of an iPhone 6 with case cradle with a hardwire cord. I don't even have a new phone yet, but I'll update this thread eventually once I've upgraded and installed a new mount.
    May 06 2014
    Las Vegas, NV
    Folks - Can someone tell me, is there enough room behind these panels to run the cable down the side behind the face place of CD player/SD card player, climate controls and then out the back of the center stack without too much of an issue???? IF so, how??? Do these faceplates just pull off/out with trim/pry tools? Or, even better, do you think a small enough cable can be pushed into the gap with a pry/trim tool without removing anything except the climate control in order to get the cable out the back of the center stack????
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by the4siswickid View Post
    You'll want a set of Audi radio keys to remove the radio. With that out, it's very easy. I wouldn't try to cram a cable down the side as it's rather tight.
    You can also remove the vents, as shown above, by removing the dash trim piece. Just take your time and don't rush and you should be fine.
    May 06 2014
    Las Vegas, NV
    The mount that I am going to use actually utilizes the CD slot and it's a hardwire mount. I just need to route the cable behind the stack and don't want to pull apart a bunch of the items on the stack to do it. If I just remove the radio, can I get the cable out the back of the stack?
    Mar 28 2009
    Minneapolis, MN
    Yes, I ran mine that way.
    May 06 2014
    Las Vegas, NV
    Did you get any rattles with the cable hitting other cables, etc., or did you wrap the cable in felt???? Thx man.
    Mar 28 2009
    Minneapolis, MN
    No on both counts, but I did wrap up the excess cable into a bundle before stuffing it inside.
    May 06 2014
    Las Vegas, NV
    Awesome, thanks brutha!!!!
    Veteran Member Three Rings OldSport//'s Avatar
    Jun 17 2014
    Texas
    The cool thing about these is that now you can order them with a hardwire power cord, making install a breeze. I'll probably go the route of an iPhone 6 plus case cradle with a hardwire cord. I don't even have a new phone yet, but I'll update this thread eventually once I've upgraded and installed a new mount.
    Thanks for the information, I'll likely go this route at some-point as well! Do keep us posted.
    *Previous* 2014 DSG S4 - Glacier White | Black Nappa | B&O | MMI | Carbon Atlas | Peelers
    *Previous* 2014 6MT S4 - Brilliant Black | Black Alcantara | Black Optic | Sport Diff | B&O | MMI | Carbon Atlas | Side Assist | Stoptech 380mm Trophy BBK | TSW Nurbs | EuroCode Sways and End Links | 034 Transmission Mount | 034 Rear Diff Mount | Spulen Diff Mount | CR-15 Strut Tower Brace | SRP Racing Pedals
    Mar 28 2009
    Minneapolis, MN
    I finally got around to ordering a new ProClip mount for my phone. I was tired of using a vent clip holder and the cigarette lighter for power, and this is a much more elegant solution. I got the ProClip 527666, "Apple iPhone 6 With A Case Adjustable Charging Holder with Tilt Swivel for Hard Wired Installation for Small to Medium Cases." The iPhone drops right in and onto the Lightning plug. I use a pretty slim Spigen case on my phone, and it works perfectly with this cradle. I'm still using the same PanaVise mount mentioned in the first post in this thread.
    No more overcomplicated cabling needed, since my B8.5 streams over bluetooth, so I don't have to run to the AMI port in the glovebox anymore. The cable goes from the cradle, into the center stack next to the CD player (which is the only part I had to remove from the dash to install it), and behind the glovebox to the passenger fuse block. Install was a breeze once I figured out which fuse to use, and once I realized that I didn't have to pull the whole glovebox out to run the wire, thanks to this tool, which I have no idea what its official name is.
    Veteran Member Three Rings cchoi83's Avatar
    Nov 10 2014
    Long Island, NY
    Cable fishing retractable claw thingamajiggy.
    2018 RS 3 | Nardo Gray | Crescendo Red | Dynamic Plus | Black Optic | RS Design Pkg | Tech Pkg | Dynamic Pkg
    P3 | XPEL Ultimate Full Wrap | Nanolex Si3D HD
    I swear I'm keeping this one stock.
    Eventuri CF Intake | JRZ RS PRO3 | BBS CI-R | Michelin PS4S
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    Edit: Just reading again and it feels like bad form for me to post a pic of my setup in your setup thread lol. Will make a new one.
    Very nice setup you have here. I had a buddy with a 2001 Mustang Cobra that did a similar setup. Yours looks clean.
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by cchoi83 View Post
    That sounds right.
    Nov 10 2014
    Long Island, NY
    That sounds right.
    Btw, this is off topic but I just wanted to say that your previous wheel setup with A8 wheels was really impressive. I was sad to see that they had gone to a new owner.
    Mar 28 2009
    Minneapolis, MN
    Ha, thanks. I liked them too, but I have a very short attention span when it comes to wheels. The S4 is now gone too. That particular set of wheels sold to a guy in California, but now they're back in Minnesota on a friend's C5 allroad.
    Veteran Member Three Rings djnuge's Avatar
    May 15 2015
    So the PanaVise 75102-109 will work for the 2015 Allroad?
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by djnuge View Post
    Yes. The hard points haven't changed.
    May 03 2015
    Austin, Texas
    Has anyone tried the pro clip dash mount? It looks very similar to the panavise and apparently it just clips into the seam where the panavise requires removing panels and screwing in. I could see the panavise being more sturdy and slightly more clean, but seems easier to install.
    Aug 24 2015
    Naples, Florida
    Hey everyone,
    Just wanted to would share my recent iPhone dock install. Thought it might help someone else looking for options. I was looking for a solution that would allow me to charge my phone, as well as have quick and easy access. The proclip seemed to be the best solution I have come across online. I was originally going to try to hardwire the mount, but decided to keep in relatively simple.
    Mar 21 2015
    ^ move it to the right vent so you can still get your air.
    Aug 24 2015
    Naples, Florida
    Thanks for the suggestion. I thought about that at first but decided to keep it on this vent because it puts my phone in perfect hands reach.
    Senior Member Two Rings Quidproquo's Avatar
    Aug 06 2015
    2013 Audi S4, 2007 Nissan 350Z Enthusiast
    Morris County, NJ
    I can reach mine just fine, and I'm pretty vertically challenged.
    2013 B8.5 S4 DSG (034 Motorsports intake tube | air box mod | aFe Pro Filter | CTS+183mm Iabed Pullies | EPL Dual Pulley 93 Pump Tune | SunTek 35% Tint | 19" S5 Rotor Wheels)
    Aug 24 2015
    Naples, Florida
    Wow, your setup really does look a lot cleaner also. Good points everyone! I'm purchasing the ProClip Angled Mount right now lol. Now if only the bluetooth audio and navigation loaded faster when you turn on your car. It literally takes a couple of minutes for both my navigation and bluetooth to start working. My 2011 BMW 335is worked instantly and I just picked up a 2016 S4. I really do love the car but just it's just one of those things that I don't understand.
