Results 1 to 22 of 22
    Senior Member Three Rings mik34's Avatar
    Feb 04 2010
    Manitowoc, WI
    Centric brake pad review
    Ok, so the weather has improved enough for me to comment on dust production from my Centric brake pads. Basically, it's similar to OEM. Maybe slightly improved but not much. Not too suprising since they're metallic. Performance is also similar to OEM (which is great). So in the end, I probably wasted a bit of cash on these and will upgrade to ceramic pads when someone gets around to releasing them.
    Sold: 2013 : Ice Silver, Carbon inlays, APR tuned, 21x10 HRE S101, AWE exhaust, Carbon fiber mirrors from RS6, Drilled rotors, H&R lowering module, Escort 9500ci, Ceramic brake pads, Deval carbon fiber rear diffuser, Xpel Ultimate, Opticoat
    Sold: 2009
    Whoever said money can't buy happiness...doesn't own a (tuned) S6.
    Veteran Member Four Rings moosehead1's Avatar
    Dec 24 2013
    '16 Cayenne GTS
    CO Rockies
    +1, received mine last week, the color and consistency of pad material looks near OEM. Again, these are the semi-metallics so no real surprise. Another captain obvious note, I was surprised at how much larger the front pads are vs. the rear. Sure the fronts bear the load and visibly are bigger hardware, but it is really noticeable when the braking pad surface is laying side by side.
    It shouldn't be that difficult to get the ceramic pads produced, as they already have the proper plates, mounting gear, dimensions for our vehicles. Would be nice to have 'em for springtime hard driving.
    Veteran Member Three Rings TheChef's Avatar
    Aug 30 2010
    Houston TX
    But the thing neither of you mentioned....do they dust less?
    #ProjectS7 2013 & 2014 SEMA Feature car w/ HRE
    Glacier White. Quilted. Innovation. Carbon. LED. Big Red Brembos.
    Partner's: HRE Performance Wheels. Audi. APR. H&R. Michelin. TiKore. EVOKlass. Eurowise. Mothers.
    Feb 04 2010
    Manitowoc, WI
    Quote Originally Posted by TheChef View Post
    I mentioned it. They dust like OEMs, maybe slightly better. Not the fix I was hoping for.
    Sold: 2009
    Nov 18 2013
    2007 Suburban 3" lift/33" Terra Grapplers
    United States
    The EBC yellow stuff for an S7 should fit an S6.
    Feb 04 2010
    Manitowoc, WI
    Quote Originally Posted by airborne6 View Post
    EBC says "high dust" on their website for the yellow stuff pads. No thanks.
    Sold: 2009
    Nov 18 2013
    United States
    Speaking with the rep today he ensured the yellow's put out the least amount of dust of all their pads, and would be drastically less than OEM. For my suburban they advertise 90% less than stock. I wouldn't say it's that much but it is less than what OEM's were.
    Aug 30 2010
    Houston TX
    Could it be worse than OE? lol
    Nov 18 2013
    United States
    Established Member Three Rings gatorguy's Avatar
    Jun 12 2013
    BMW M5, Ford Expedition Limited
    Metro Orlando
    Per the EBC website:
    Yellowstuff is not rated as low dust and creates similar dust to OEM pads, if low dust is what you seek, Redstuff should be your choice for fast street use.
    http://ebcbrakes.com/product/yellows...nd-track-pads/
    2013 Estoril Blue S6
    20" Giovanna Sardina's|ECS Spacers|Custom Spoiler|30% Ceramic Tint|Blacked out filler panel|Escort Max hardwired|Escort ZR4 Laser Shifters|Opti-coat 2.0|Stasis Rear Sway Bar|Audi Puddle Lights
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    Quote Originally Posted by mik34 View Post
    ...So in the end, I probably wasted a bit of cash on these and will upgrade to ceramic pads when someone gets around to releasing them...
    Ceramic pads are already available for your car: http://shop.advanceautoparts.com/c2/...ds-shoes/16463 (In case the link is broken, they're Advance Auto Parts Wearever Gold, part number GMKD1575)
    I've have this same pad formulation on my car for a couple of years now - they don't dust AT ALL. The initial bite isn't quite as good as the OEM pads, but that's to be expected, and the full braking power remains essentially unaffected. The bite/no dust tradeoff is one I'm very happy with. Here's my writeup of my experience with before/after photos:
    http://www.audizine.com/forum/showth...hlight=cheapie
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Established Member Two Rings SierraBravo's Avatar
    Jan 23 2012
    Greenville, SC
    We are talking about the S6 here. The Advance Auto Parts web site says the pad number you gave does not fit the 2014 S6.
    2014 Phantom Black S6, Eurocode Sways, End-Links And Alu Kreuz, Milltek Cat-Back Exhaust
    Previous - 2012 Monsoon Gray S4
    Jan 19 2010
    MI/CA
    Quote Originally Posted by SierraBravo View Post
    Au contraire, mon ami...
    Look again - According to his signature, the OP's car is a 2013 S6, and the part number I cited fits that car, according to AAP's website.
    Feb 04 2010
    Manitowoc, WI
    Are you sure they're ceramic? They say they fit the S6 but here's the description: "Either Ceramic or Semi-Metallic depending your vehicles original equipment." I'd guess they're semi-metallic.
    Sold: 2009
    Jan 19 2010
    MI/CA
    I guess you'd have to contact AAP to be certain.
    My car came with semi-metallic pads, too, and the Wearever Golds for my car are definitely ceramic. They also don't dust at all, which was the main point in my case....
    Feb 04 2010
    Manitowoc, WI
    Quote Originally Posted by zcd2.7t View Post
    That would be nice. Thanks for the tip.
    Sold: 2009
    May 10 2013
    Boston
    I was planing to put the Centric pads I purchased in Jan on the car when I swapped tires in a couple of weeks. Glad I read this thread. I'll check out the Wearever pads to confirm they are ceramic or wait for another manufacturer to ship them. Anyone want to buy a set of Centric pads?
    May 10 2013
    Boston
    I decided to put the Centric pads on the S7. The front OEM pads have vibration dampers on them. Did you reuse the old dampers or buy new? If you reused them, was it easy to get the old ones off?. Did you need any adhesive to reuse?
    Feb 04 2010
    Manitowoc, WI
    Quote Originally Posted by sladans1ma View Post
    I had my dealer swap them out as I don't know how to do it. I don't notice any vibration or issues so I'm guessing they used the OEM dampers.
    My HREs are now the victim of severe dust. Unless I use Sonax everyday, it's a futile battle. Someone PLEASE release ceramic pads.
    Sold: 2009
    Established Member Two Rings Josec70's Avatar
    Dec 26 2013
    Miami, Florida
    I swapped my OEM pads both Front and Rear with Akebono Euro Ceramic pads and the difference is unbelievable; zero dust and wheels always seem clean. I don't feel performance has suffered either in regards to responsiveness or stopping distances. While my car is a C7 / A6 I would explore whether Akebono intends to release an application for the S6.
    2012 A6 3.0T
    Mods:
    20" x 9" Velos Designwerks Forged Solo VII Wheels / Eibach Pro- Kit Springs / Pirelli P Zero Nero 255/35/20 / Black Calipers (S-Line Decals) / Gloss Black Wrapped Grille Edge / Matte Black Wrapped Window Trim / Akebono EUR Ceramic Brake Pads / Passport 8500 X50 Hardwired w / Remote Smartcord / APR Stage 1
    Dec 24 2013
    '16 Cayenne GTS
    CO Rockies
    ^While waiting desperately for ceramic pads, I've had some nominal success using Gtechniq C5 nano coating on my wheelsets. It at least provides for a half week of semi-decent looks and the dust can be sprayed off once or twice with water pressure only, even if the barrels still are dusted. Sonax and woolies only come out once every two weeks with a full wash.
    My NIB set of front and rear semi metallics are free to a good home.
    Can you just smell the market opportunity?
    '13 S7: SRM RS7 CHRA, DS1, SRM TCU, APR HX, Screen Delete, Exhaust Mods, AWE CAI, RS7 Skirts, HR Module, Belstir+ & LI Quad, FB Wheel, 3M Tint & Bra, BBS CI-R with PSS
    Gone: '06 Touareg / '00 A6 2.7T / '94 90CS / '86 Coupe GT
    Feb 04 2010
    Manitowoc, WI
    ^ Yeah, I'm waiting for a full detail. Going to put Opticoat on car and wheels but looks like that won't happen until June.
    Sold: 2009
