Results 1 to 7 of 7
    Deactivated Four Rings
    Aug 30 2013
    2014 Toyota Highlander Limited, 1999 Mercury Grand Marquis GS-HPP
    Panama City Beach, FL
    Jacked the front end, now have hard brake pedal
    Last night I replaced my sway bar end links and I also removed and reinstalled my motor mounts (due to excessive vibrations), and after I finished I started the car and let it run for a few minutes and ran it through the gears so the mounts would settle, then I lowered it and did a quick drive around the block before I torqued the mounts in place. The brake pedal was extremely hard, so I scanned it and cleared any codes that were there from the MAF being disconnected, but it didn't help the pedal at all.
    Any advice on what may have happened? I'm not sure how air got into the system, unless something has failed or there's a vacuum leak somewhere, because I'm not leaking any fluid. Thanks!
    Nov 19 2013
    Cape Town - South Africa
    Have you checked that the vacuum hose has not come lose and that your check valve is still in place?
    Established Member Three Rings V2Rider's Avatar
    Feb 11 2014
    2011 Jeep Grand Cherokee, 2007 Audi A4 2.0T Quattro, 2006 GSXR 750 (very fast ) :)
    Minneapolis, MN USA
    Quote Originally Posted by kegobeer View Post
    Did you check all vacuum lines? I know jacking the motor up can pull on some of them. Just a thought
    2007 Audi A4 2.0T Quattro TIP /Debadged/Piston DV/Hids/APR Stage 1 AMSOIL
    Veteran Member Four Rings xander3zero's Avatar
    May 30 2013
    Rhode Island
    If air got in the brake system your pedal would be soft right? Because air compresses more than brake fluid? Correct me if I'm wrong
    Sent from my Nexus 7 using Tapatalk
    2017 Audi S3
    Mythos Black Metallic | Dynamic Package | Tech Package | S Sport Seats | Bang & Olufsen
    Previous:
    2013 Allroad Premium+
    2006 A4 Quattro 6MT
    Aug 30 2013
    Quote Originally Posted by xander3zero View Post
    Yes, you're right. I'm thinking vacuum problem, from all the responses so far. I'll take a look tonight and see what I find.
    And, since this is my money pit, I now have a small leak in the transmission area...hoping it's just a seal and nothing more serious. Argh.
    Thanks for the help!
    Aug 30 2013
    This turned out to be a quick fix. Like others guessed, it was a vacuum line that came off when I jacked the engine. I popped it back on and my brakes are back to normal. Thanks again, everyone.
    Feb 11 2014
    Minneapolis, MN USA
    Just as I thought, I know raising the engine pulls on things, I'm glad it was an easy fix!
