Results 1 to 4 of 4
Thread: P0501
    Established Member Two Rings 98 A4 Quattro's Avatar
    Oct 03 2012
    Midwest, USA
    P0501
    Okay, I replaced the speed sensor that is behind the drivers side front wheel last summer, didn't work, but that fall I was driving and the speedometer randomly worked for .1 of a mile, I was so excited until it stopped working again. I have the magnetic drive wheel ring purchased but it seems to be a pain in the ass to get that cover off the side of the transmission to get to it. Is it possible that I just have a wiring issue? The RPM gauge works fine, (Yes my rev is limited to 5200 rpm), the fuel gauge works when it wants, the coolant temp and oil temp gauges work well. Just absolutely no speedo and sketchy gas gauge. I have the ABS Light on solid, and a blinking Brake light which to my understanding is the ABS Module (common for b5) I have 3 codes. the p0501 for speedo and p0432 which is main catalyst bank 2 below threshold and one for my secondary air injection pump. Which from my understanding pushes fresh air through the cats. Sorry for getting off topic just wanted to list all the information and hopefully someone can get my on the right track.
    | 1998 Audi A4 Quattro V6 30 Valve | Cat-back Exhaust | Short Throw Shifter | Cold Air Intake | Performance Clutch | 17's | Lowered 2" |
    | 2004 Audi S4 | AWE Tuning Cat-back Exhaust | Short Throw Shifter | K&N Drop-in | Blacked-Out |
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    What brand sensor did you replace it with? I wouldn't trust anything but a brand new OEM sensor. Better yet, try a known to be working sensor off a friends car if you can. After that I would check for continuity in the wires before going in to replace the magnetic ring. I've done it, it's no fun. It also didn't end up fixing my problem since I had a bad sensor all along. I had replaced it with a Meyle sensor that was faulty from the factory, a used OEM sensor fixed my problem.
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
    Oct 03 2012
    Midwest, USA
    Im going to volt test the sensor and the wiring see if I'm not losing juice anywhere, also may give it a shot on the 52$ genuine sensor off ecs
    Jul 27 2011
    IN
    Quote Originally Posted by 98 A4 Quattro View Post
    I replaced mine two yrs ago with genuine Audi sensor from GAP and never looked back at it. You can get the OE sensor for $32 + shipping from GAP.
