So a few weeks back I posted on here about wondering if I had a boost leak because I was only boosting 7lbs. After a lot of feedback and research it turns out my aeb engine was not having any boost leak. But it was running very healthy at 7lbs with peaks around 9. Now about 5 days ago check engine light came on and at the same time car would not go past 2lbs of boost. The codes were cylinder 3 missfire and evap code. Well it turned out that spark plug for cylinder 3 was broken. And I found that the evap check valve was burned. After replacing all plugs and evap check valve car is running the same. It's such a hog I don't know how to explain it.... I have a buddy who has a geo metro. We raced just as a benchmark and he took me off the line and threw 3rd gear. Once I hit about 45 in 3rd gear I started to slowly gain on him. It's like 1st-3rd gear no matter what rpm I'm in if I floor it all u hear is the intake get throatier and loud but no increase in speed. Is this more than just a boost leak? Btw. I did a boost leak test and it would not hold boost at all but I couldn't actually pinpoint were the boost leak was coming from. Leading me to believe its watergate actuator. But what I'm worried about is even if my turbo wasn't working at all would the car be this slow? I can't even merge into traffic without cutting someone off? Maybe I need to change coil packs? Idk just really frustrated. And don't know what to do.
