Results 1 to 10 of 10
    Jan 25 2013
    United States
    tire rubbing?!! 🙏🔪🔫
    Hey fellow audi enthusiasts, i am here today tryna figure out why are my tires rubbing . I am assuming there rubbing. When i turn the wheel all the way either side it causes a vibration . Please give me ur $.02..
    Apr 07 2011
    What size wheels? What size tires? Offset? Are you running spacers? Suspension? More info goes a long way...
    Jan 25 2013
    United States
    245 35 17 5 spoke oem rims non sport shocks and springs maybe needs replacing not sure. No spacers ,thanks for the quick reply
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    They're rubbing bcuz racecar Either you're alignment is messed up REALLY bad, or something else is rubbing on the tire (wheel well liner?)
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Quote Originally Posted by audi252 View Post
    Zero reason or way your tires are rubbing. Get under the car and have a look.
    Senior Member Three Rings JAYINH's Avatar
    Apr 19 2013
    f350 dually
    GRANITE STATE
    ^^ this....did you take a peak yet ^^
    2003 1.8t-air lift -19" LM reps- motoza 1+ - meth, other shit.....
    Jan 25 2013
    United States
    The car is aligned its drives straight on the high way and steering is correct when tires are facing forward. Also just got it done like 4 months ago. When i look i dont see nothing out thr ordinary
    Jan 06 2009
    Take a look for physical wear marks indicating something is rubbing...Otherwise it is probably a humming wheel bearing.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Apr 07 2011
    There's gotta be plenty of room in that wheel well to stick your head in there and see what's rubbing, your on non-sport suspension.
    Veteran Member Four Rings mauromj's Avatar
    Jul 22 2012
    Pullman, WA
    CV joints...
