Results 1 to 7 of 7
    Active Member Two Rings RubenS4's Avatar
    Feb 12 2005
    Oettinger
    Norcal
    Where is the least expensive place to get an intake manifold for an 07 a6 3.2?...new
    It appears that the runner number 1 flapper is stuck and causing my cel issue. I can't smog my car till the cel is addressed. I'm going to attempt to carbon clean my intake but if the pin for the flapper is broke, I may have to source a new or used one.
    Driving german performance since 1980.
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Feb 16 2012
    2006 Audi A6 4.2L Quattro Sline
    Los Angeles, Ca
    Audi 06E-133-210-K Intake Manifold for 3.2L engines
    Replaces 06E-133-210-E, 06E-133-210-F, & 06E-133-210-J
    2006-2009 A4
    2007-2009 A4 Cabriolet
    2005-2011 A6
    eBay: http://www.ebay.com/itm/2007-Audi-A6...13c7cf&vxp=mtr
    or try the other models listed
    Feb 12 2005
    Oettinger
    Norcal
    Thanks for the lead! I wasn't aware of the interchangeability.
    Apr 07 2010
    2019 A4, 2018 Subaru Outback
    Southington, CT
    There may also be an easy fix. 4Dr1ver4 from Audiworld recently had a problem with his passenger side intake manifold runner. The problem was that the white plastic ball which fits into a socket on the actuator had worn to the point where it would not stay in the socket. He put a screw through the actuator socket and ball to hold them together and the car is working great. The fix was quick and essentially free. Go over to Audiworld and post the question.
    Feb 12 2005
    Oettinger
    Norcal
    Sounds pretty straight forward. I really don't want to buy a new or used manifold if it's only a part within the manifold assembly has failed or fouled. Once I get in there, I'll have to access my options. Did the OP do a write up or at least post pics of his solution?
    Apr 07 2010
    Southington, CT
    Unfortunately he did not. Post over on Audiworld and ask him.
