Purchased July 2013 with 100k miles.
Timing belt was done early September, coils replaced on December.
Took it yesterday morning for a IMAF Motor recall.
Waited 2.5 hours, then the service rep. tells me: "We're gonna have the car washed, should be ready in 10 min."
15 min passed and he came back and told me "Oh, they took your car for a test drive and the car started shaking and the Low Oil Pressure message came up, so they had to stop. We're going to tow it back to the dealer and figure out what happened."
So I had to leave it there, they gave me a ride to Enterprise to rent a car to come back home (it's a 1 hour drive).
Service rep called me at 4:15pm and said that they can't really figure out the problem but the master technician thinks there is a mechanical problem inside the lower part of the engine, they're gonna check for problems and they'll cover the costs.
But if they can't figure it out, then they'll have to move on to lowering the oil pan and examine the oil to see if there are any metal shavings that could've caused the problem, and check the oil pump BUT they'll have to charge me for it and it's around 5 hrs of labor.
He called again this morning and said they checked the oil with the dipstick and it looked good, so the next step is to lower the oil pan.
They're waiting for me to call back and see what I want to do.
What should I do, or can I do?
The car was fine before I took it in, I drove 1 hour on the freeway to get there and it was running fine. He claimed that the service they did for the recall has nothing to do with the oil pressure problem.
I was going to check the Cam Follower because previous owner never looked into it, so maybe it broke and that's what caused the problem. Would the extended warranty cover everything?
