Results 1 to 4 of 4
    Mar 18 2014
    ford sierra saphire rwd.
    killarney, kerry, ireland
    Loosing Power! at high rpm 1.9tdi!
    hey guys, i own a 2003 audi a4 b6 1.9tdi its the aux engine model and its a se model too 130bhp 1.9tdi, i have noticed the last couple of weeks that it looses power over 3000rpm when its on full throttle from 1500rpm and only in 2nd or 3rd gear i mainly notice it? but when i use full throttle from 2500rpm up to redline it doesent loose power it pulls great. any ideas guys? it always does it t the same rpm around 3100rpm. would it be the egr valve failing? thanks guys!
    Dec 15 2011
    Edmonton Alberta
    any codes? Intake plugging... turbo actuator seizing/not holding vacuum...
    -Richard-
    2009 Rabbit. 1961 VW Beetle Canadian Std. 2012 Ram 1500.
    Darsh Import/Dubsport Inc... My very own VW/Audi parts and service shop
    Certified VW/Audi Tech 20 years +
    Mar 18 2014
    no plugged in with vcds and shows no engine faults the turbo is perfect too. i used vag com in engine section to move the actuators and everything seems to be working perfect. i also done a vacum test on it last week and there was no leaks every pipe is perfect, the only thing i did notice is around the egr valve on top there is oil around it, is that a sign of the egr valve going? everytime i go full throttle from 1500rpm to redline it drops power/boost at 3100 without fail and when i go full throttle from 2500rpm to redline is pulls great like it should nearly everytime. thanks for a reply. any more clues to what it could be? beside a egr valve?
    Dec 14 2013
    Minnesota
    Few of us in N. America have this motor in our A4s (I kinda wish I did.....)
    You are best served going to http://tdiclub.com/ and checking out their forums for help.
