Results 1 to 2 of 2
    Established Member Two Rings JABOWSI's Avatar
    Nov 28 2013
    United Kingdom
    B7 VAG-COM Codings and results
    Can anyone help me with VAG-COM codings for headlights.
    I have Halogen headlights on my car in the UK (Euro)
    I have retrofitted Bi-Xenon but still have the main beam on the inner reflectors.
    This is because if the headlights are off when I use the main beam flash only the inner halogen beams work.
    When the bi-Xenon dipped beam is on and I use the main beam the Xenons flick into main beam(the cutoff drops down on the solenoid) AND the inner main Halogens light up.
    My question is can I recode it to be Halogen with DRL? what will become the DRL?
    Also if I want to code it as ###14 will that make the fogs become DRL and what will happen to the headlights?
    Hope all this makes sense..
    Euro Headlights & DRL
    Module 09 (Central Electrical), recode to ###XY, where:
    X = DRL
    0 – Halogen without DRL
    1 – Halogen with DRL
    2 – Bi-Xenon with DRL
    3 – Bi-Xenon without DRL
    4 – Bi-Xenon with DRL / tail light / license plate light
    Y = Locale
    1 – Rest of World / Nordic Countries / Denmark / Croatia / Baltic Countries with Bi-Xenon
    2 – Nordic Countries / Denmark / Croatia / Baltic Countries without Bi-Xenon
    3 – USA / Canada with Bi-Xenon
    4 – Canada without Bi-Xenon
    5 – Special Vehicles
    Jul 11 2012
    Uden
    You need to run 2 wires from the light module (under the steeringwheel) to the headlights, just like the kufatec harnas. Hook these wires up to the high beam wires coming from your retrofit kit. Them code it ###21. Now your high beam wil become your DRL.
