Results 1 to 16 of 16
    Jul 18 2009
    D2 S8, E61 535xi, B5 S4
    Subdivisions, NW burbs
    034 rear adjustable control arms
    Anybody use them? Like them? Thinking of getting a set.
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Your camber off? Or running out of stuff to buy :)
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Jul 18 2009
    Quote Originally Posted by infinkc View Post
    Why I ought a...hahaha!
    I might need to introduce a smidge to fit the wider wheels and tires after going lower. Maybe just lowering will do the trick though?
    Jan 24 2008
    Pennsylvania
    Bought but not yet installed, for my B6. They appear to be quite a quality built piece. I bought them to dial in proper camber for track use.
    If you already know you may have some rubbing/contact with your wheel specs, these could help. But better to install the wheels and see if you need them before buying IMO.
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    Jul 18 2009
    Cool. I will lower and see where its at. Just preparing for the possibility.
    Veteran Member Four Rings Gujuhammer's Avatar
    Oct 07 2010
    02' Avant
    Florida
    I got a set on the car but have only put a 100 miles on them...Car is under the knife currently (as we discussed) but should be done this week. I'll report back once I get some miles on them.
    How do you like the Lamarr Houston pick up?
    Jul 18 2009
    Nice! Who's doing the work?
    I like it. I wasn't too upset with Peppers until he signed with the enemy. Judas Peppers. They still need a better interior d line push/run stop though and not really loving the safeties they signed but I guess anything is upgrade from last seasons
    Oct 07 2010
    02' Avant
    Florida
    Quote Originally Posted by happy2B5 View Post
    Dynarev, which is a highly reputable shop that is sort of local to me. I should be picking up the car on Thursday but we will see...
    I really didn't expect to resign Peppers, but the whole GB thing blew me away. He's a a shell of what he used be...I'm not worried. I think the draft will be where the Bears fill the rest of their needs you mentioned...DT (1st round), Safety (2nd round). The safeties they picked up are just bodies...I only see one of them making the team and he will be a back up/Special teams.
    Jun 01 2008
    Apopka, FL
    I couldn't comment on the rear's specificly, but I can say (since they have the same ball joints) that 034's implementation of ball joints is both a benefit (fully rebuild able arm) and a disaster. What I mean by that is, you're supposed to be able to remove the allen bolt to the pin and just turn the joint to adjust the arm, but that doesn't work, because
    A) you can't even torque it to their specification (the pin just spins, I had it cranked down as hard as I could in a vice and still coulnd't get it to spec)
    and
    b) the same goes for the nut which is suggested to torque to 45ft/lbs and use loctight. I don't have an open ended torque wrench (I don't know anyone that reasonably does) so it too, isn't right.
    when you tighten these as much as you can and put them in the car, you then can't get the arms loose to make adjustments, so that means you're going to pop the joints out of the pinch and try to man-handle the nut loose to then make adjustments.
    Veteran Member Three Rings 2BblkAudis's Avatar
    Feb 15 2007
    San Mateo, CA
    I've got the rears and have no complaints. Finding an alignment shop that actually has the proper alignment rack to do the rears properly is more challenging and expensive.
    I did my best to count threads on the inner ball joints so they are even and just had my alignment guys adjust the camber.
    If you have some negative camber with aggressive offset wheels you might run into rubbing.
    My goal was to get my alignment within factory specs so i don't wear my tires prematurely or unevenly.
    Good luck.
    Jul 18 2009
    Ya. I have 18x9 et29 wheels with 245/35 tires. Current camber specs are -1.7 front and -1.6 rear at ride height of 25+ front and 25++ rear.
    When you say rubbing, you mean fenders? I understand that if so. Or are you meaning rubbing on these 034 units? Just clarifying. Thanks.
    I'm fortunate to have a great alignment shop. He sets up all sorts of scca club cars, Porsche, minis, miatas, etc. He's solid. Has all my cars dialed in and doesn't charge an arm and leg to do it right.
    Veteran Member Four Rings 2380S4's Avatar
    Jul 16 2008
    2001 S4 Avant, 07 DTM S4, 15 328XI & 90 Turbo Grand Prix
    Living The Dream!!!
    Quote Originally Posted by SAUDI01.5 View Post
    I heard they working on a nice setup there. You'll have to keep me posted on the new setup as I'm looking to do a simple setup now that I sold my GT build.
    Current: 2018 RS3 Audi Exclusive Navarra Blue Stage 2 ECU 93 & TCU Unitronic, Intake, Inlet, Intercooler all Unitronic, Downpipes APR, ECE dogbone, KW HAS, APR coils, 7437-9 plugs, Eurocode Sway Bars & End Links.
    2001 S4 Avant Brilliant Black STG 1, ST Coilovers, AWE Twin 2, XS Power DP's, Neespeed Rear Sway Bar, 034 Adjustable End Links, 034 TBB & Bi-Pipes
    Past: 2007 S4 DTM
    Past: 2001 S4 10 years
    Past: 2013 A5
    Garage: 1990 Pontiac Turbo Grand Prix 1 of 3400 made in 89&90
    Oct 07 2010
    02' Avant
    Florida
    Quote Originally Posted by 2380S4 View Post
    Word travel fast ;). I will definitely do that. It has taken a little longer than I expected but that's the nature of these cars as we all know. Adam has been great and kept me updated daily as the build progressed. As with most things the end result will determine how happy I'll be.
    I'm going to start going to the cars and coffee (Sat. mornings) in the SW burbs if you want to come by and check it out. Also joined the Audi club of Chicago and should be showing up to many of the events.
    As I've stated to you before, I'm really disappointed that you didn't put that monster in your car. I sure you have a good reason for doing so, but that engine was so damn pretty...You could have hung it on a wall and called it art ;).
    Jul 16 2008
    Living The Dream!!!
    C&C I have been doing the north one (Vernon Hills) one since it started pretty much may make it down that way depending on work schedule. That's were I heard about a B5S4 with Adam and put 2 and 2 together..
    Back on topic as I have been looking at these for a while as my bushing in the rear are in need of serious replacement. So if we could follow up down the road with feedback on how they perform that would be awesome.
    Past: 2007 S4 DTM
    Past: 2013 A5
    Feb 15 2007
    San Mateo, CA
    Sorry I should have clarified that the issue would be rubbing the fender.
    Another thing that came to mind was potentially finding shorter hardware for the outer joint. At your ride height the length of the bolt may rub against the inner fender liner. I haven't had any issues but the alignment shop made a point to mention it to me.
    Good luck.
    Jul 18 2009
    Quote Originally Posted by 2BblkAudis View Post
    Good luck.
    Thanks for the info and feedback!
