Results 1 to 10 of 10
    Veteran Member Three Rings USAFS4's Avatar
    May 05 2008
    2008 Audi RS4; 2017 BMW M240xi Dinan stg 1
    PCC Potomac/Chesapeake
    Rear Sport Diff Leak: Audi says must be one drop/second?!?!
    So tuning shop notices some leakage from my rear sports diff. Take to dealer and tech tells service writer who tells me that Audi defines a LEAK as something like "one drop per couple of seconds." WTF?!?! Anyone else heard of this? I forgot the exact number of seconds per drop, but does it F'ing matter.
    I'm going to contact another dealer to double check but if this is true holy F; Audi is just ensuring they don't have to replace a poor design before warranty ends.
    Anyone have a real sport diff failure yet because fluid got to low? Wonder how many miles on average that will take. Probably should just figure a $9k repair at some point during the life of the car.
    2008 B7 RS4, Jackal Tune, w/JHM spacers and Flap Delete
    2012 B8 S4 Stg II APR. SOLD.
    2000 B5 S4 (Audry) Stg III: 390Hp & 435Tq. SOLD. Wish I kept it!
    Junior Member One Ring
    Mar 12 2014
    CO/BC
    That's a plan.... interested in hearing more about this.
    yikes!
    ‘12 997.2 Turbo S Cab
    ‘18 991.2 GT3
    ‘19 MB AMG C43 wagon (outgoing)
    ‘23 RS6 Avant (incoming)
    Apr 04 2012
    MSP
    LOL -
    A leak is a way (usually an opening) for fluid to escape a container or fluid-containing system, such as a tank or a ship's hull, through which the contents of the container can escape or outside matter can enter the container. Leaks are usually unintended and therefore undesired.
    So if it was unintended for fluid to be escaping the rear diff through a seal or whatever it's leaking from - then it's defined as a leak. If it's covered under warranty you'd think the dealer would be happy to take on such a nice big job!
    Veteran Member Four Rings helix139's Avatar
    Apr 21 2010
    Florida
    There is a TSB on leaking seals on the diff. Do you have an actual dripping leak or simply grease getting slung on the underside and your axles? You should be able to search and find the TSB number fairly easily and reference that when going to the dealership.
    2011 S4 Premium Plus 6MT, Sepang Blue Pearl, Black Silk Nappa, Sport Diff, B&O, B8.5 MMI 3G+ Nav, Ti Pkg
    APR Stage 2+ Stock/93/100/Valet, Eurocode Alu Kreuz, Eurocode USS Sways + End Links, Eurocode Meisterwerk SSK, Roc Euro Intake, Apikol Rear Diff Mount, Fast Intentions Exhaust, Escort 9500xi, Laser Interceptor, P3 Vent Gauge, VCDS
    Oct 02 2013
    Redstone, CO
    Leaky SD has been discussed here recently. Do a search.
    2014 S4 Estoril Blue, Black Opt, 19" Rotor, Side Assist, Carbon Inlay, B&O Sound, MMI/NAV, Rear Camera, Advanced Key, Supercharged badges, H&R OE, Track+ Spacers, 10/15mm, otherwise stock.
    May 05 2008
    Quote Originally Posted by levigarrett View Post
    I know it has been discussed, but my dealer basically said that they are not going to address it unless it is dripping. I believe most threads have discussed material being slung into the chassis. I have not looked at myself, but my tuning shop thought it was important enough to mention.
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Here's a pretty lengthy thread (with pics and details) about the leaking sports diff issue, and the TSB that resolves it. I had the problem on our 2011 - barely dripped on the garage floor, but what got slung onto the exhaust system would make the garage smell like hot oil whenever it was parked. The dealer took care of it without any hassle.
    http://www.audizine.com/forum/showth...ight=leak+diff
    Here's a description of the fix on the invoice of a repair ...
    Cause: LEAKING
    39881903 AWD FINAL DRIVE ASSEMBLY REMOVE + REINSTALL
    3817 W40 3.70
    1 D-454-300-A2 SEALANT
    2 4F0-501-269 PROTEC CAP
    12 N-900-972-04 BOLT
    42212050 DRIVESHAFT REMOVE + REINSTALL
    3817 W40 1.30
    42242099 REMOVE AND INSTALL 2 CONSTANT VELOCITY JOINT CAPS
    3817 W40 0.20
    01210004 TEST DRIVE
    3817 W40 0.10
    FC: 422950002002
    PART#: 4F0-501-269
    DESCRIPTION: 3522 INSUFFICIENT SEALANT ON LEFT AND RIGHT CV JOINT PROTECTIVE CAPS INSPECTED SPORT DIFF AND FOUND FLUID LEAKING FROM LT AND RT CV JOINT CAPSR. R+I FINAL DRIVE SPORTS DIFFERENTIAL, R+I LEFT AND RIGHT REAR DRIVESHAFTS, R+I LEFT AND RIGHT CV JOINT PROTECTIVE CPS, APPLY SEALANT TO LEFT AND RIGHT CV PROTECTIVE CAPS, ROAD TEST VEHICLE FROM X TO Y MILES, ALL DIAGNOSTICS AND REPAIRS PERFORMED PER TSB # 2026049/1
    If your dealer refuses to fix it because it's "not dripping enough", I'd recommend contacting AoA or finding a different dealer.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    May 05 2008
    Quote Originally Posted by LYKUNO View Post
    Cause: LEAKING
    3817 W40 3.70
    3817 W40 1.30
    3817 W40 0.20
    01210004 TEST DRIVE
    3817 W40 0.10
    FC: 422950002002
    PART#: 4F0-501-269
    Thanks. This is helpful. And I think my dealer may lose my business. It will be interesting to see what another dealer says. Won't be able to get another dealer to look at it for 2 weeks. I'll post and update then.
    Jul 18 2010
    NE Ohio
    Almost forgot, here's a link to a docx-formatted description and diagram for the TSB, illustrating the parts involved:
    https://docs.google.com/file/d/1mOnc...tJf/edit?pli=1
    May 05 2008
    Awesome! Thnx. By the way mine is a 2012. So guess this updated sealer may have not made it into early model 2012s.
