Whats up guys, another problem that hopefully will be as easy to figure out as my last one. I put my stock dv back on and it makes a flutter noise upin release. My boost gauge reads -8 at idle and will normally boost 5-6 psi. Yesterday it started misfiring and bucking pretty bad under slight load and barely noticeable under wot. It was also idling all over the place from 500-2000rpms.I replaced the spark plugs and the problem went away. Now it returns randomly but not as bad. However im only boosting 3psi when it comes back. After it goes away again the car comes alive and will boost up to 8psi however only in 4th. My boost psi falls off really fast. No codes or cel. Thanks for your help. Only mods are cai.
