Results 1 to 7 of 7
    Established Member Two Rings BCAPR's Avatar
    Nov 29 2013
    b.c.
    Super High mileage engine swap
    Im at 128k for a 2009 in Canada and not experiencing problems YET but down the line Im sure the automatic will go and the engine will be a sludge fest. It is on apr stage 2 for the past 10k+ so warranty is not a possibility.
    POSSIBILITIES:
    -TDI and transmission from europe or ROW market.
    I have auto wrecker options and can access non public auto auctions;
    -2.0 from a newer a4 or even a tts?
    -v8 4.2 from an s5
    -3.0 supercharged??
    -A 5 Liter LS motor? LOL
    Easy to convert auto to manual? what about Dual clutch?
    How viable are these options???
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    128k? You consider that super high milage?
    Do a compression test, leak down test, see what the health of the motor is. As long as you have been on time with your oil changes sludge should not be an issue.
    128k these days...you have just now broken the engine in. With proper care there is no reason to believe you cannot get another 100k out of it unless I have missed something.
    2016 S3
    Instagram- @Thisisastickup
    Active Member Two Rings dewenny's Avatar
    Feb 16 2014
    A4 b8 2.0 TDI
    Ninove/Belgium
    My neighbour is a cabdriver with an A6 280k miles + still drives like new!! proper care goes a long way with Audi!!
    Less is MORE
    Nov 29 2013
    b.c.
    I'm talking waaaaay down the line guys :) just like to plan for the future
    Oct 27 2010
    Norwood, MA.
    WAYYYY down the line.. i would say 3.0t! For one it will fit into your engine bay 100%, with minimal fab work, re-pin the harness and be good to go pretty much, and readily tunable for much more power! Easier said than done but the way Audi builds their cars swapping oem engines aside from the wiring nightmare is as easy as it could get.
    By then maybe that engine will be available at a cost less than an arm
    And a leg.
    2016 S3
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    ^ what b6hate4 said.
    If you are gonna swap motors go big or go home!
    Veteran Member Four Rings name.goes.here's Avatar
    Mar 17 2012
    South of Boston
    Quote Originally Posted by A4 Centaur View Post
    Agree; otherwise, what is the point.
    His: 2015 Audi A6/Quattro/Glacier White/Premium Plus/Bose/Cold Weather Package/Sport Package
    Hers: 2016 Infiniti QX50/AWD/Majestic White/Premium Plus Package
