Results 1 to 6 of 6
    Active Member One Ring 4RINGFAN's Avatar
    Aug 11 2011
    2001 Audi B5 Avant 2.8, 2003 Audi TT Mk1 1.8T 225HP, 2008 Audi TT Sline roadster 3.2, 2013 BMW 328xi
    Rochester, MN
    Clutch engagement point.
    I'm curious if anyone has suggestions on how I could possibly change the point at which the clutch on my 2001 B5A4 Avant engages. It seems like my knee needs to be almost completely up before the clutch is engaged. The clutch itself is new and was replaced recently by Anderson Motorsports in the cities. Ok, I'm probably just used to all of my more modern Audis where the clutch pedal starts to grab somewhere in the middle of its travel, and I'm just spoiled.
    I've been told that it is a hydraulic system and that there are no adjustments. So, I HAVE adapted to it.
    I figured if anyone knew of a modification, it'd be you guys.
    2001 Audi B5 A4 2.8 Avant
    2008 Audi TT S-line roadster 3.2
    2011 Audi B8 S4 Supercharged 3.0 TFSI DSG APR Stage 2+
    2013 BMW 328Xi sport line
    Gone:
    1998 Audi B5 A4 2.8 Avant
    2003 Audi B6 A4 1.8T Avant
    2006 Audi B7 A4 2.0T
    Senior Member Two Rings Ryanic's Avatar
    Jun 03 2013
    Minnesota
    I haven't really looked into modifying it, all I know is B5 series have really high engage points. Annoying at first, but once you relearn it's not an issue. Annoyed the hell out of me when I first got my B5 A4 after my first car with a really low engage point lol.
    Aug 11 2011
    Rochester, MN
    Hehe, yeah, EXACTLY! My knee should not have to be into my chest before the clutch grabs! I DO have it figured out now, but man, the first time I drove it, lets just say that I'm glad that a bunch of people weren't watching! I was starting to get on the gas early expecting the clutch to be engaged and it wasn't prettty. Not pretty at all. LOL.
    Now, I'd just like to see the engagement point lowered for more rapid response in first and 2nd gear. Hack saw the pedal off maybe? (Not serious)
    Gone:
    Veteran Member Three Rings disturbed_audi's Avatar
    Oct 13 2012
    mk4 jetta 2.0, 2003 R6 Ltd Edition, bagged body dropped 92 S 10
    Indiana, PA
    Mines the same way dont like it but been driving it two years and you sort of get used to it.
    01 Audi A4 QMT 17"avus, atp testpipe, forge splitter
    92 S-10 manual 3 inch body drop, bagged tucking 3 inches on 18's
    03 Yamaha R6 powercommander
    mk 4 2.0 vw jetta
    Senior Member Two Rings JaysA4's Avatar
    Feb 17 2013
    2000 Passat 1.8t FWD 1998 2.8qm 1999 1.8qmt
    Champaign IL
    I've had 5 B5s plus a B5 Passat and its just seems to be the norm for these vehicles. Just put a brand new clutch kit and slave on the 2.8 last month and it still has a pretty high engagement point. I'd say just try to get used to it lol.
    Sent from my SAMSUNG-SGH-I717 using Tapatalk
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    Buy a aftermarket clutch kit that uses a pressure plate that has more clamping load then the stock pressure plate, this will cause it to need more pedal travel to release the disk completely.
