Results 1 to 15 of 15
    Dec 10 2013
    Borden, Ontario, Canada
    Messy stripped bolt
    Any ideas how to get this bolt out of the rear diff bracket?
    Established Member Two Rings Bruch's Avatar
    Nov 24 2009
    Irwin, PA
    I don't see a picture, but maybe it's this iPad.
    Bruch
    '00 A4 Avant V6 MT
    '01 A4 Q 1.8T Tip
    '95 90 Quattro Sport
    '97 A4 Q 2.8 5 5spd
    '00 A6 2.7T
    '93 90S FWD (junked)
    '88 90Q (sold)
    '90 20v 90Q (sold)
    Veteran Member Three Rings Halfrican's Avatar
    Oct 25 2012
    United States
    Quote Originally Posted by Bruch View Post
    The picture is broken.
    Feb 06 2013
    WV
    Can't see it but take a nut and hold over the bolt and weld down through center of the nut. The heat from the weld will expand the bolt and break it loose from whatever that has it hug. You can use the nut to turn it off after letting it cool just a little bit. Not a lot though.
    If the head of the bolt is in good shape take a torch and heat it up and the same thing as above.
    If you can read this thank a teacher, since its English thank a veteran...
    Audi make a great car, but their heater cores are, well $h!t.....
    Dec 10 2013
    Here's the fixed image
    EDIT: Having trouble getting the image to show
    EDIT2: Fixed
    Veteran Member Three Rings ElliottG's Avatar
    Apr 30 2009
    '12 Q5 2.0T
    Still broken. You need to take the direct link and use it in the [img] tags.
    Here it is, though.
    Dec 10 2013
    Quote Originally Posted by zandrew View Post
    As you can see in the fixed image, it's pretty much stripped circular. I don't have access to a welder either.
    Nov 07 2010
    South of Heaven
    The other option is to drill the head of the bolt off just leaving the stud of the bolt and then replace it. It is pretty tight there and may be hard to fit an extractor but a drill will make short work of it.
    - 2000 Audi A4 QTM
    - 1994 Corrado VR6
    - 1991 Jetta G60 Coupe Syncro
    Veteran Member Four Rings bhusted's Avatar
    Sep 11 2011
    B5 A4 4.2L V8
    Kirkland, WA
    Welding a nut on the end would probably be the cleanest method for extraction. Without that, I think you'll have to go with a sharp bit and drill out the head. Those hex key bolts are hardened, so it will take some work. Make sure you oil the bit as you drill. Once you've removed enough of the head of the bolt, you should be able to remove that bracket and grab the remains of the bolt with a pair of vise grips to remove the rest. Take the remains to your local hardware for a replacement.
    To avoid this in the future, set the hex key in the hole with a hammer before you start wrenching. If you suspect if could be a tough one, heat the bolt with a torch and then hit it with as much water as you can. Heating and cooling the bolt will usually break it free from any rust.
    | B5 4.2L V8 Quattro | Tein S-Tech | O.Z. Ultraleggera 18x8 | Stabila Course 22mm rear swaybar | Agency Power WRX swaybar links | S4 front brakes | A8 rear brakes | FX-R HID projector retrofit | Fog projector retrofit | RS4 Grill |Aero wipers |
    Feb 06 2013
    WV
    Quote Originally Posted by Bordom View Post
    I was in a pinch the other day with a head bolt that holds the caps on. I took a dremel and a cutting wheel and took my time and cut 6 sides on it so I could get a wrench on it. Came right out. I have also seen people use a cut off wheel and simply cut a groove in a blt and use a flat head screw driver to remove it.
    If this don't work then simply drill the head off and remove with vise grips as stated. I have had to do this as well and it works.
    Feb 22 2014
    Omaha, NE
    What i've done with several of mine is taken a 12mm socket and a hammer and pounding it over the bolt so it's on tight. Then you can pop it loose with the socket wrench and take a small screwdriver and a hammer and pound the bolt back out of the socket.
    Not sure you will be able to fit a socket in the bracket on that bolt though.
    Senior Member Two Rings MrSnickelsnizer's Avatar
    Dec 03 2012
    michigan
    Take a torx that is a pretty good fit but the points extend past the stripped center hole. Then line it up and beat on it with an extension connected to it. Beat it in in till the points have cut new grooves in the bolt. I just did this on the three of the four crank bolts for the crank pulley. Then when it is in there nice and snug twist out the bolt. It works 90% of the time on stripped allen bolts.
    Dec 10 2013
    Thanks for all the replies and great suggestions! Failing any of the above mentioned (besides welding on a nut) would I be able to chisel/hammer it out?
    Apr 22 2007
    Riverbank, Ca
    Soak it in PB every hour, Hit the bolt with a hammer medium strength (Not enough to do damage if you miss..), repeat. Then do above, and yes a chisel method works but you have to be very aggressive. I like to cut a slot with a dremel first then start chiseling.
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
    Established Member Two Rings twofaze's Avatar
    Jul 26 2008
    Fort Worth, Tx
    I would just get a Irwin stripped bolt socket set from Advance. It grabbed my two stripped allen head bolts
    on the A/C adjuster pulley and cam gear when I did my timing belt. I had tried many of the methods
    listed above. Bought me a set, five minutes later they were off.
    in da hood we say "don't drink & drive, park & sip"
