Results 1 to 19 of 19
    Established Member Two Rings Peenge's Avatar
    Mar 25 2013
    Meatball, Sweden
    VCDS wont connect to 56-Radio.
    Hello people!
    I have searched and i have searched again, but no luck..
    My car will not connect to 56-radio to program AUX-in. Most other functions are accessible. I have VCDS 11:11:13 with Ross-tech HEX+CAN Dual-K & CAN <-> USB interface for VCDS Rev.B.
    Have any of you had similar problems with connecting to certain controllers? I can access engine, brakes, lights etc..
    Hope someone can help a poor, cold and lonely polarbearhunting Swede out:)
    _|_
    2013 - 2017
    EURO 2008 B7 A4 1,8T 6MT Quattro
    | BSR PPC stage2+ | JR panel filter | Ray´s 2,5" dp-back exhaust | 034MS test pipe | Turbosmart Kompact DV | Full s-line & black optics inside & outside |
    Mar 25 2013
    Meatball, Sweden
    And for my other question, do any of you guys know of any diagnostic software that can program my radion, other than VCDS? Preferably compatible with USB interfaces, not COM1 etc.
    _|_
    2013 - 2017
    Active Member Four Rings waiapasi2006's Avatar
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Did you try resetting your radio?
    Waiapasi2006
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Quote Originally Posted by Peenge View Post
    Hello people!
    As for your software, try updating it as a trouble shoot or delete it and re-download it.
    There can be multiple reasons for it. Start with the basics.
    Waiapasi2006
    Mar 25 2013
    Meatball, Sweden
    Quote Originally Posted by waiapasi2006 View Post
    Well i´ve tried just about everything, software, interface, different computer, different OS, i even took apart the OBD connector in my car and checked for damages.. I'm being sent a replacement now to eliminate the cable being the fault. It seems that the CAN protocol does not communicate, might be the decoder in the cable itself, i hope.
    The fault codes indicating communication error are completely random.
    How do i reset my HU? And i assume that i need my radiocode afterwards, where do i find it?
    Thanks for your help bro!
    _|_
    2013 - 2017
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    What head unit do you have? RNS-E or basic symphony I or II?
    Waiapasi2006
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    At least you tried all that above. So they are sending you a replacement cable from Ross tech?
    Waiapasi2006
    Mar 25 2013
    Meatball, Sweden
    I have a Concert 2+ HU. And yes, im being sent another ross-tech cable! Not directly from ross-tech tho!
    _|_
    2013 - 2017
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Your code for whatever radio you have should be in your owners manual. Unless you bought something and just installed it without the code, then you have another problem.
    Waiapasi2006
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Well, let's hope when you get the new cable, you get all your issues resolved.
    Did you locate you security pin?
    Waiapasi2006
    Mar 25 2013
    Meatball, Sweden
    Thanks again! I will look in the owners manual tonight! Do you know how i reset the HU?
    _|_
    2013 - 2017
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Is your HU working for now or not at all?
    Waiapasi2006
    Mar 25 2013
    Meatball, Sweden
    Everything works perfectly fine!
    _|_
    2013 - 2017
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    I would say do this;
    If your HU IS WORKING now, leave it as is until you can locate your security pin.
    If your HU don't have the security pin, don't do anything else until you get that in order.
    You don't want to drive around without a non working head unit.
    Waiapasi2006
    Mar 25 2013
    Meatball, Sweden
    If you HU IS WORKING now, leave it as is until you can locate your security pin.
    If you don't have the security pin, don't do anything else until you get that in order.
    Absolutely, i would not reset anything without my radio code!
    _|_
    2013 - 2017
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Absolutely, you don't want more issues right now.
    Waiapasi2006
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Waiapasi2006
    Mar 25 2013
    Meatball, Sweden
    I found my radiocode in the owners booklet
    Skickat från min GT-I9505 via Tapatalk
    _|_
    2013 - 2017
    Mar 25 2013
    Meatball, Sweden
    Just tried programming my cousins 2KA Caddy and i could connect to 56-Radio... So i guess the problem is in my car somewhere.. From what i read the communication is via K-line, but i assume that it could be either Can-bus or K-line that is faulty!
    _|_
    2013 - 2017
