Results 1 to 25 of 25
    Feb 11 2014
    Dallas
    Angry Hhheeeeelllllppppp!!!!!!
    Hey guys, I've got a 02 1.8T. I've had a k04 and chip for a while and wanted to get more performance. I was recommended to port and polish the intake and exhaust. We found out they used abrasive material to do it like gritty sand. So I got with my friend that tunes Hondas and we decided to try it ourselves. We got a bag of sandblasting sand and hooked up into the intake and started the car. We had to hold the gas so it would run. He wanted to let the engine suck in the sand through the intake so it would port it out and then push it out the ehxaust so it would port the exhaust manifold.
    I was worried that it might cause problems but he figured it'd be OK as long as we didn't make boost and it get sucked in the turbo. After running the car and letting it suck in sand we got about half way through a 25 lb bag. The check engine light was on and the engine was bucking and kicking and sounding really weird. We stopped and hooked the car back up normal and took off the sand supply. We tried to start it again and it was really hard. Once started it couldn't idle and kept making weird noises. We took it out and drove it and it started to make scraping and knocking noises.
    Help! Can anyone tell me what to do! My buddy only does Hondas so he doesn't know much about Audis.
    haha just joking
    Veteran Member Four Rings Myst420's Avatar
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    Please, don't EVER touch anything under the hood of a car again....You most likely destroyed your engine.
    When a machine shop ports and polishes pieces, they do it with them DETACHED from the motor.
    02 A4 Quattro 1.8T
    Votex kit, Neuspeed race springs and Koni struts, 18" AT Italia Flash Sport wheels, painted lowers.
    Nuespeed: Chip, Exhaust, Short Shifter, Rear Sway-Bar, Dual Side-Mount Intercoolers, Forge Splitter.
    Veteran Member Four Rings Rocs's Avatar
    May 25 2009
    Audis
    Conshohocken, PA
    "I was here"
    Active Member One Ring HalfCat's Avatar
    Dec 16 2013
    Your Mom
    Your Threadz
    I'm here for the gangbang.
    You done goofed.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Is this real life?
    Has to be a troll..
    2019 SQ5 Prestige
    Jan 20 2012
    Houston, Tx.
    Tis a troll.
    Exact same wording used back in 2007. That thread blew the phuck up and was known across all automotive communities.
    http://m.audiforums.com/forum/showth...0267&styleid=4
    We're on to you op....
    Apr 01 2011
    B5 on jack stands
    charlotte
    this has got to be a joke right??
    either your "friend" intentionally fucked you over..or you're both dumbasses.
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    Quote Originally Posted by ponchiz View Post
    Tis a troll.
    Thank god...now can we get this bitch banned?
    02 A4 Quattro 1.8T
    Apr 01 2011
    B5 on jack stands
    charlotte
    that was a good one.. lol
    Veteran Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    2006 A4 Avant S-line
    SL,UT
    Lol, nice try wanna-be troll. You fail at trying to fail.
    Thanks for the EFF shack. -Dirty Mike and the Boyz
    Apr 01 2011
    B5 on jack stands
    charlotte
    I wonder if he's a Honda guy
    Feb 11 2014
    Dallas
    LOL. I was trying to make some people smile and laugh. Saw this on audizine and just had to post.
    Jan 20 2012
    Houston, Tx.
    Ah the good ole days. Found out about that thread through bimmerforums back then. Other renown threads to remember were the guy with the b5 that sprayed bed liner over his paint to avoid dents, the guy working on his motorcycle and accidentally put his hand on the chain, the mustang guy that filled his engine with water in order to clean it out completely, the*guy*that literally welded the gears in a differential, one guy that used jb weld in order to seal the crack on his engine block and had a catastrophic failure.
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Tis a troll.
    Yeah I was going to mention this, but looks like you got it first
    This exact post gets popped up with people trying to be funny.
    Jun 27 2011
    Trolololooo. At least use something that everyone doesn't know about.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Three Rings rich045's Avatar
    Jul 13 2013
    Queens, NY
    i think the one about the cheating girl friend and the coolant leak is more epic, lol
    Jan 20 2012
    Houston, Tx.
    Quote Originally Posted by rich045 View Post
    You mean the one about the bmw motorcycle? Yeah that was awesome.
    Jun 08 2007
    Orlando, Fl
    I remember that thread back in 07 on Audiforums. I even responded I believe. Within seconds of reading the OP I realized what this was.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Mar 05 2013
    CA
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    I think there was another one less than a year ago or something with the same context.
    RAI Test pipe / TT DP / S4 rear sway / Motoza stage 1 / SAI delete / IE Blockoff plate / S4 Front Recaros / B7 Center Console
    http://www.flickr.com/photos/27286038@N03/
    Senior Member Two Rings WTFISAKSERIES's Avatar
    Mar 01 2013
    Nj
    TROL MAYBE?!?! IF NOT Lmao i thought this was a joke!!!!!!!!!!!!!!!!!!!!!! You need to go to Kmart an get a huffy and never i repeat never look or work on a car again!! Fool!
    04 B6 1.8t Quattro - Audi TT 225 injectors APR DV - ECS Fuel pressure gauge stock K03 at 18psi for now (Bigger turbo & 60lb ev14s scat Rods coming soon) ST Coilovers - OEM Front Control arm kit - OEM sway bar bushing - CX Racing FMIC - Mirro 18s wrapped in 225 45 18r N3000 - Carbon Fiber Interior trim - Podi steering column pod and gauge - Straight 3in CAT - TT TUNING STAINLESS DOWN PIPE -Magna Flow B6 dual 2 1/2in Exhaust - TUNED by Napoleon at 18psi.
    Aug 31 2011
    Lathrop
    Just pick a random section of words from that post and google it. Look at all the different forums it has been posted on.
    I used:
    "in sand we got about half way through a 25 lb bag. The check engine light was on"
    Veteran Member Three Rings Audi body's Avatar
    Jan 03 2013
    bike and a pit bull powered pair of rollerblades!!
    the woodlands tx
    Ahahahajajaj
    Senior Member Three Rings DaSkorpion's Avatar
    Apr 11 2009
    o4 Audi B6 1.8TQM - o2 MB CLK 55 AMG - o8 Kawasaki Ninja ZX-10R
    CT/NY/NJ/PA
    Quote Originally Posted by HalfCat View Post
    W here do I get in line for the gangbang?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by DaSkorpion View Post
    Where do I get in line for the gangbang?
    Age before beauty. Move back in line Bubba.
