To make it simple.
1. Get a KKL FT232RL Cable so you can use NefMoto Flasher to get the .bin (code) ripped off of your ECU via the OBD2 port.
http://www.ebay.com/sch/i.html?_odkw...L+kkl&_sacat=0
2. Open the file in WinOLS.
3. Figure out where the emissions code is and follow proper procedures for coding out (I am unsure but I am Sure that is has been covered on nefmoto)
4. Ensure checksums are correct and flash it back to your car's ECU.
Note: most tuned ECUs are encrypted but I know there are some tuners that sell bootlegged ECU software. No need for complicated galletto cables that can require ECU removal. MPPS cables I didn't like because they all come with bootleg software that I personally wouldn't trust flashing my ECU with. Nefmoto ME7 flasher works pretty well with that cable I posted above. You can also use that cable with VCDS. Our ECUs aren't the hardest to code, but you should know what you are doing before attempting to tune your own ECU. Pretty sure the ME7 has safeboot mode if it is going to brick itself!
