Results 1 to 4 of 4
    Mar 10 2014
    Cabe
    New Owner, need some opinions
    I recently purchased a 2007 a4 avant 2.0t manual. I want to lower the car and I also want to add more power. What is the most cost effective way to add decent power? I was thinking about an upgraded turbo but the couple I've seen are in the thousands of dollars. I know a chip is a fairly cost effective mod but how much performance gain am I looking at with something like that? Most any work I can do on it myself so installation price isn't a problem. Let me know what you guys think
    Senior Member Three Rings SwiftA4's Avatar
    Aug 20 2012
    Search around the "B7 Dyno" thread for some numbers from APR and some other companies. APR, Revo, Unitronic, JHM (soon), etc... are the tunes provided for us for the 2.0T application. Just search around for the tunes and you'll be able to see what performance gains are available at different stages.
    2008 A4 S-Line | APR Stage 1 93 | Ibis White | 2.0T Quattro Tip | Koni FSD/Eibach | Debadged | R8 Coilpacks | BKR8EIX | OEM Roof Rack | VEI/Podi | 15% Side, 5% Rear | Rev. "D" DV | 034 Snub |
    Retrofits: S4 Power Folding Mirrors | Warning Triangle |
    Established Member Two Rings MWP's Avatar
    Dec 02 2013
    NoVA
    Performance gain with a chip is very noticeable. If you have an APR dealer nearby you can try out their tune for free for 6 hours of driving time. A test pipe or high flow cat will help performance too.
    Garage
    2018 SQ5
    2021 Q7
    Retired:
    2016 Q5 3.0T - EPL Stage 1 ECU/TCU
    2014 Q7 PRESTIGE - Bone stock
    2005 B7 A4 2.0T QUATTRO 6MT - Revo Stage 1
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    Best way to do it is: Chip it and add a divertor value(used $50), install a straight pipe you get from : CL, Ebay or a part out here on AZ or other Audi forum (Internet). To add additional power --get used injectors and a used turbo (kO4) from the same sources as the pipe. I'd say with enough diligence you could add the tune for $450 oe a bit less on sale and $100 for a pipe---so $600 total for that----and you could get a used turbo for $400-500, injectors like $250. So the whole mess for less than $1500 if you were on it and industrious.
    It'll take some work, but all that is easily doable to turn that car into a real racer.
    The biggest cost, however, will come later as your car, pushed beyond what the engineers envisioned, starts to crap out, parts failing here and there. Then your "budget build" will cease to be cheap and will cost you real $$ and real time. Hopefully your time isnt worth much money.
