Results 1 to 27 of 27
    Jan 25 2013
    United States
    shit is annoying!!
    morning fellow audi owners i have a real issue i replaced the cts 4pin and 2 pin and im still getting a fan on the cold start and my gas consumption is retarded i run threw gas i also jus replaced the fuel filter but the filter is not leaking im just goin insane can it be a faulty sensor or what im so fed up the stealership said it cant be the termastat so what are my option i believe the code is p3081 . Oo ya a4 b6 1.8t quattro
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    That code is tied directly to the G62 temp sensor. If you replace the sensor you may want to check the harness for continuity. It may not be getting the signal properly or at all.
    Are there any other codes?
    19537/P3081/012417 - Engine Temperature too Low
    Possible Causes
    Coolant Temperature Sensor (G62) faulty
    Possible Solutions
    Check Coolant Temperature Sensor (G62)
    Check Coolant System
    RAI Test pipe / TT DP / S4 rear sway / Motoza stage 1 / SAI delete / IE Blockoff plate / S4 Front Recaros / B7 Center Console
    http://www.flickr.com/photos/27286038@N03/
    Veteran Member Three Rings rich045's Avatar
    Jul 13 2013
    Queens, NY
    just because the sensors are new doesnt mean they are not faulty. when i replaced the one that went on my rear coolant flange with a new one, i had the fan problem, so i put back the old one and the problem went away. just my .02 cents
    Jan 25 2013
    United States
    I was very delicate with the wires when I replaced a g62 to sensor should I just look into replacing the G62 again i did buy it of amazon lol can that also save me gas since its runing rich. Thanks everyone
    Apr 07 2011
    Was it an OEM sensor?
    Feb 12 2008
    Michigan
    Do you have the old one you can swap back in to check it?
    Jan 25 2013
    United States
    It is not oem to me it looks aftermarket ...the old one was the reason why i swapped it. The ad said oem but idk for sure. I just need to swap with another one. But can it be anything else besides sensor i changed my coolant and bleed the system . It seems fine
    Oct 02 2006
    Wadsworth,OH
    Grab a Genuine Audi sensor, some of the aftermarket ones are not great quality, we have them available below.
    Jason
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Does your engine heat up normally? Is it up to full operating temperature within no more than 5 minutes? do you have good heat in the cabin?
    Jan 25 2013
    United States
    I get good heat once the fan shuts off the car worms up normally once the fan is one OG... n ECS i purchased the 2 pin and stuff from u but im sorry i recieved to many wrong items im okay for now
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by audi252 View Post
    Feel free to PM me with instances, I'd like to have things like this documented for areas of improvement.
    Thanks.
    Jason
    Jul 13 2013
    Queens, NY
    i put one of those green ones and the fan went on, got a code on vag that would not go out and the fans would go on, i forgot what it was. i replaced it with the old blue one that was in there and he code and fans went away.
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    ayeyo brah parts bin gittin' hit up wif stuff namayne so LMK whatup how you gawn ficks da car. WORD!
    May 11 2008
    Columbus, OH
    sheeeeeeit. I kuld bearlee reed dat
    Veteran Member Four Rings Myst420's Avatar
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    Quote Originally Posted by Elliott View Post
    LMAO...my thoughts exactly.
    02 A4 Quattro 1.8T
    Votex kit, Neuspeed race springs and Koni struts, 18" AT Italia Flash Sport wheels, painted lowers.
    Nuespeed: Chip, Exhaust, Short Shifter, Rear Sway-Bar, Dual Side-Mount Intercoolers, Forge Splitter.
    Oct 02 2006
    Wadsworth,OH
    FYI if your vehicle came with a blue temp sensor chances are you have a B5 and not a B6. All B6's came with green temp sensors.. B5's up to VIN 8N-Y-015000, (the split is in 2000 model year) only had blue 4 pin temp sensors.
    Jason
    Jan 25 2013
    United States
    Lmfaoo dat was funny i couldnt read that eitha lol and ecs i was going back and forth with u a few days a go all u said is i can refund and dat aint wat i need i need troubleshooting and u said idk what to tell u ...and wats da part numba for this blue for pin?
    Jan 25 2013
    United States
    So no blue top for me...uhhh man i need a solution cause the code be4 i replaced it would come and go and so would the cold start issue now it dont wanna leave
    Jul 13 2013
    Queens, NY
    Jason
    Last thing I remember, This is a B6 (silver), not sure if someone can confuse it with a b5. if the sensor is blue and i get no dtc, then the sensor stays in, lol
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    I'm getting a headache reading this thread...
    OP, you may have a bad thermostat.
    Also, you said you bought the sensor from Amazon, not ECS....and why would you expect a parts house to troubleshoot for you?
    02 A4 Quattro 1.8T
    Oct 02 2006
    Wadsworth,OH
    98% of the time the fans coming on is the sensor. I literally just had the same issue. My temp sensor was failing which caused my gauge to work intermittently and eventually stop working, my fan would came on upon cold starts as well. Then finally it caused my car not to start when it was cold. Had a new Genuine sensor installed and it fixed everything. No fans running, no cold start issues, and the gauge works as it should now.
    Like I said before aftermarket sensors are hit or miss. If the sensor you got from us is causing problems we'll be more than happen to refund you for the one you purchased. It's highly advised to use a Genuine sensor for this particular situation - you don't need the blue sensor it is not for your vehicle.
    Jason
    Oct 28 2007
    Ocean Beach, CA
    Nov 11 2010
    Rochester, MN
    19" B8 S5 Peelers
    May 11 2008
    Columbus, OH
    ^LMAO Best pic I've seen on this forum.
    Feb 11 2014
    Dallas
    Its the thermpstat. After the same BS that your going through I gave up and replaced it. SHIT sounded like a rattle can after I took the old one out. Thats how busted it was. Spring ...... what spring? REPLACE THERMOSTAT. I had the same codes as you.
    Feb 11 2014
    Dallas
    Jason
    that other 2% is the thermostat
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    geez... longest run-on sentences ever...
