Results 1 to 9 of 9
    Mar 11 2014
    Houston
    Ipod Touch iOS 7 is incompatible with AMI connection
    Just upgraded my iPod Touch to iOS 7. My iPhone 4s is not yet upgraded. Now, my iPod cannot be detected via blue AMI cable. iPhone 4s still connects via same blue cable. Need to get iPod Touch reconnected. I have: 1) restarted my ipod, 2) Synced to iTunes, 3) connected to AMI cable with cable already connected, 4) Disconnected AMI cable from car then connected iPod to AMI cable first then connected back to car, 5) Called local Audi dealership's service advisor. None has offered solution.
    2011 Audi A4 quattro. Using blue AMI cable. My MMI version is HNav_US_P0114_D1.
    Oct 14 2013
    2014 A4 Premium Plus, Sport, Black app, MMI
    Which ipod touch? I've used my iPhone 5 with iOS7 and had no issues, but I'm in a 2014 A4 with MMI 3G+ so it might have something that your car doesn't in terms of compatibility.
    Is your car MMI 3G I assume? Have you checked if there are any MMI upgrades available?
    Veteran Member Three Rings Roadtrippn's Avatar
    Sep 15 2011
    Hilton Head Island
    Yeah IOS7 blows. If you can't figure it out, buy a restored ipod classic off amazon and just leave it in the car permanently. They're 80-140$ and I can fit ALL my music on there. I picked up an 80GB for cheap.
    Senior Member Four Rings r6_11b8's Avatar
    Oct 03 2013
    los ángeles
    try getting tune 2 air and run everything via bluetooth….i was having problems with my i phone as well especially when playing music through pandora downloader and regular pandora(jailbroken)…at the end of every song it would pause an go to the first artist i had in my music library….i took my car to the dealer cus my door latch broke…and they said they had a software update or campaign to perform…i got my car back and my ami was fixed completely…it doesn't freeze or do any weird crap plays what i play without it going to my regular music library
    maybe you could try this?? or running a tune 2 air and run everything via bluetooth???
    2011 A4 ice silver metallic
    MODS- 25% tint rear, 75% front, 19" Rotiform BLQ, Solo Werkes coilovers, Custom FXR projectors
    upcoming mods - 10 inch sub
    2009 Yamaha R6 - Shogun FS-Zero Gravity-Custom FE-Hot Bodies Flush Mounts-MotoDynamic Integrated Tail Light-Supersprox -1+2-Taylormade Full Exhaust-PCV-OURY Grips-Corbin Seat-Ebay Shorty Levers
    Jan 18 2014
    Oklahoma City, OK
    In iTunes I converted all my AACs to MP3, deleted the AACs, and copied my library to a SD card. I actually like that a lot. I know its not a direct answer to your question but I figured I would offer a comment.
    Mar 11 2014
    Houston
    Quote Originally Posted by rampantandroid View Post
    Thanks. If I don't get a AMI or BT solution working, I will try some of the workarounds posted here. My ipod touch is the 60GB, Model MC547LL/A, Version 6.1.6. So, I guess I'm not running iOS 7 afterall. Regardless, the AMI fail began 2 weeks ago when I upgraded this ipod's software. I'll try the BT connection. The car has MMI 3G. The dealer's service advisor said there were no MMI upgrades currently available. But, they seemed to be pretty clueless on the phone having to put me on hold to ask other advisors before answering my question. So, I plan to look further to see if I can upgrade to MMI 3G+ like you are running.
    Jun 14 2009
    GA
    For what it's worth, I have no issues with my iPhone 5S or iPad Mini on iOS7. Either via direct AMI (30-pin to Lightning adapter) or via the Audi Bluetooth Adapter. Both work fine.
    Car is a 2010 A4 w/ Radio Concert.
    2018 IA6 3.0T Sport | Glacier White Metallic | Black Optics | Carbon Atlas | XPEL PPF | Gyeon Quartz
    Gone, but not forgotten:
    2014 A6 P+ Quattro, Quartz Grey Metallic
    2010 A4 P- 2.0T Quattro 6MT, Quartz Grey Metallic
    2007 A4 S line 2.0T 6MT, Phantom Black Pearl
    Mar 11 2014
    Houston
    I just learned that Version 6.1.6 is, in fact, the latest update for iPod Touch. So, I do suspect it causing my issues. I have sent an email to Audi customer service and will post anything here if it solves the problem
    Jan 04 2013
    IL
    Have had same issues as OP for past 6 months now
