So I installed my JHM intake spacers yesterday and it was one hell of a long day! I watched the supplied video and it seemed easy enough, but just the number of connectors, hoses and lines that had to be removed and reconnected was challenging while not breaking anything. I have big hands which didn't help the overall process but a good 6-7 hours later I had everything put back together and triple checked every hose and clip.
I fired it up and it ran very rough and threw a flashing check engine light about 5-10 seconds after the start with a smokey exhaust. I expected a rough idle at first but the motor was misfiring so badly that the car was shaking side to side. I shut it off and called it a night feeling like shit after all that work.
This morning I double checked the hoses and clips and the injector clips/ fuel rail and that the manifold was properly torqued down then drove the car while it was still misfiring up the road to a nearby European auto shop that specializes in Volvo. The car was running horribly so I wasn't going to drive any further and had the car scanned and it showed P 305, 306, 302, 307 and P1602. I had disconnected the battery to reset the code and anything else before I had gone to the shop. Basically it came back showing multiple misfires as I had guessed so obviously it was a vacuum leak or a fuel delivery problem since their was no way that 5 of my cylinders suddenly had bad plugs and coils.
The shop did a vacuum line smoke test and no leaks were found anywhere. The codes were cleared and we started the car and took it for a test drive and it suddenly was running smoothly with no more CEL. I took it out for a good 40 min drive on the highway and stop and go and it was running very well and I noticed a little more torque from the intake spacers with consistency in pulls due to the lack of heat soak as advertised.
Anyways, any ideas as to what caused this or has anyone had similar headaches after installing the spacers? My guess is that one or more of the plastic clips on the tip of the injectors which broke while I removed the fuel rail came off and fell into the injector ports and were probably preventing the valves from sealing properly or they were somehow blocking the fuel spray pattern and then it melted away being brital and thin plastic returning the operation to normal.. Maybe I had dirt or oil on the injector tip that was clogging the fuel spray that eventually burned off? As I said the car now runs great and no issues at all but maybe the problem will come back when the car cools down and I go to start it tomorrow???
Looking forward to any comments or similar experiences.
Thanks.
