Originally Posted by
redline380
Exactly why people are doing lsx swaps in old cars, but not putting old motors in new cars (or least if they want to do it legally)
I think the cali statute reads similar to EPA statute as well, meaning that nationwide you cannot put an older motor in a car newer than the motor.
As for the swap being uncommon, it doesn't make much sense because you could just buy a 97 1.8t. Sounds like OP had a good opportunity though and got it done cheap, so why not?
As far as I know, cali emissions and doing a swap. You just have to swap everything over that is required by the state. Other reasons I just did a swap instead of buying another car.
- I put a lot of time and effort into doing other things to the car interior/exterior/suspension
- V6 transmissions have taller gears from what I've heard. I know I can hit 130mph in 4th.
- Laser Red. Not to many Laser Red B5 Audi's here in colorado that I've seen.
- I love my car, loved it since I've owned it and I know her like the back of my hand.
GrapeBandit
what did you do with the wiring/ecu? was it a direct swap? I heard the everything is different on the 96's
Everything was a direct swap over. Removed the old engine wiring harness, and put the 1.8 one in. Only things I had to "fabricate" was the fuel lines needed to be extended going to the engine and I had to reuse/bend to fit the 12v power steering line. I could have pulled them off of the passat fuel lines from gas tank to engine, and the rack and pinion assembly, but i didn't want to have to deal with that much more work to do something that was easy enough to make.
Thanks everyone for looking btw!
