Howdy guys, I'm looking for a little help here. I have had a clunk in my front suspension for quite some time, it's not that bad but it's annoying, and I want it gone. I've tried many solutions and none have solved it.
What I have done:
New 034 upper adjustable control arms (including alignments)
New S4 solid link TRE's
New control arm kit from FCP - full setup
New front sway bar bushings
New strut top bushing/bearing
All control arm bolts torqued to the correct spec, also torqued under proper load
Removed strut assemblies, I have the washer under the upper strut hat, and I added two additional washers on top to take up the slack, then used my impact to tighten.
SO...my strut assembly goes like this:
[TOP]
NUT
WASHER
WASHER
STRUT HAT
WASHER
STRUT BODY
[BOTTOM]
With all of that done, I cannot think of anything else that could be causing the clunk.
So, let's talk sub frame. I've heard of them developing cracks and causing a clunk, but I'm looking for someone who has had this issue.
Could I have a cracked/broken sub frame?
Where did the sub frame fail?
Are the fractures/cracks visible without removing the sub frame?
