Results 1 to 8 of 8
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    Injector harness
    Hey folks,
    Does anyone have an injector harness that's in known good working condition laying around that you would like to part with Looks like mine is taking a shit as i'm getting intermittent short faults on both 1 and 2....
    PM me if you do. Thanks
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Jan 06 2009
    It is not an individual harness per say, it is all part of the engine harness. Some online vendors sell replacement pigtails that you can crimp/solder in but depending where your short is that may not correct it. Take the sheathing off the wires and try to find where the short is.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Veteran Member Four Rings elewsader's Avatar
    Mar 24 2006
    2003 A4 1.8T Avant MTQ, 2001 Audi S4 Sedan
    Central, IL
    ^This is really your best option; you can get Bosch EV1 pigtails like these, and butt crimp them to the corresponding connections that you wish to replace, if you want to replace a larger portion of the harness just make sure you look for some high temperature automotive grade wiring to ensure longevity.
    I did find frayed wires on injector 2 after experiencing misfires..a thorough inspection of the wire connectors near the plug, and under the boot should hopefully indicate where your root problem is.
    Ed
    why say lot word when few word do trick.
    Apr 23 2007
    Thanks guys, yea I know its part of the overall harness (unfortunately audi didn't get smart enough until B7 to make it unplugable....)
    I was just hoping someone has it cut off, sitting around, I's rather just replace the entire thing then having to try finding where the fault is...
    I got the replacement plugs with grommets and wiring pigtails already priced out, just looking at the cheaper, easier option first.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Apr 23 2007
    Quote Originally Posted by elewsader View Post
    thanks for the link btw. I like that option better then OEM actually.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Apr 07 2011
    Another member had posted about having success with this ebay injector harness. Click Looks like the same option as in post #3 just with 4. The person who used them in his car is here. Click
    Apr 23 2007
    Thanks I'll check it out
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Apr 23 2007
    Hey can anyone confirm what gauge wiring audi is using for injector harness?
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
