Results 1 to 10 of 10
    Apr 11 2012
    2008 VW R32 Audi TT 225 mk1 audi B7 A4 1999 Jeep Xj B6 a4
    Corning NY
    can stock TIP cause surge at 75
    Car is stock except forge splitter. The dv not used as bov. Only other thing I have replaced is n75 in last 2 weeks. When going past 75 I get surge. Does stock tip collapse at that speed?
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    The collapse of the TIP is not speed related, it is boost related. It won't have an affect if you are on stock tune.
    RAI Test pipe / TT DP / S4 rear sway / Motoza stage 1 / SAI delete / IE Blockoff plate / S4 Front Recaros / B7 Center Console
    http://www.flickr.com/photos/27286038@N03/
    Apr 11 2012
    Corning NY
    Well Im getting surge when letting off the gas at 75-80. and the way I understand it either collapsing the tip or bad dv correct?
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Do you have your N249 bypassed, and if not it's possible it has failed.
    Start here and read on:
    http://www.audizine.com/forum/showth...=1#post9378177
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Apr 11 2012
    Corning NY
    No not bypassed. So bypassing it and no surge would tell me its bad correct? Any test in vag? thanks
    Dec 30 2009
    When the N249 fails it basically acts as though it is bypassed. So the only way to know is to replace the N249 (although there may be a code for failure), but before you start replacing...
    1. Check for codes
    2. Clear codes (after recording them, if there are any) and Align the throttle body (no matter what)
    3. Pressure test and ensure you don't have any leaks post MAF, this could be charge side or non-charge side
    4. Test diverter valve, test with pressure on both sides, then test with a socket and extension. With the socket and extension, press down the valve and then release, if the spring still works, then you're good. Be sure to put it back the same way you removed it, although probably ok, it just creates another variable.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Feb 28 2014
    South Carolina
    i don't think he's talking about compressor surge. Surge as in a loss of power or a buck?
    Veteran Member Four Rings ShogunR32's Avatar
    Aug 22 2004
    Quote Originally Posted by rfelker View Post
    You are experiencing compressor "stall" and not compressor surge. Compressor surge only happens when you are on the the throttle and the engine can not handle the amount of air being pushed in at the given RPM. I experienced real bad compressor surge with my old garrett 57 trim turbo with anything above 15psi. My guess is your diverter has something to do with it.
    USP CLUB MEMBER #7
    Previous Audis:Big Turbo 2005 Black Audi A4 USP 6-speed sedan/2008 Blue Audi A4 6 speed sedan/2004 OEM+ Arctic White Audi A4 Avant/2001 Red Audi TT 225Q.
    Current: 2004 BMP Vw R32
    Jun 27 2011
    How do you know you are getting surge? What is the symptom? Are the revs rising? Do you have a boost gauge?
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Apr 11 2012
    Corning NY
    ] Best way I can describe it is same as this video. And it only happens at 75 or above. Never had it until I replaced the n75 2 weeks ago. I did vag the car and no codes. also did a pressure test 2 weeks ago before I replaced the n75 and no leaks. Ill replace the n75 and clean the forge first and see if it resolves it.
    http://www.youtube.com/watch?v=nCj6Spwl1CU
