98 A4 30v non-DBW, no immobilizer, 5-speed Quattro
I have searched, but there is so much info out there, sometimes different people claim different things, now it's kinda confusing. Done a lot of searching on here but just about everyone has a DBW car and they're using the 40v.
I'm trying to figure out the best option for me, end goal is just a factory V8 in my A4. I don't have a never ending budget, so cheaper is better, but I'm not going to skimp on needed items. I'm not terribly worried about the price for the engine, 3 junkyards near me have flat-rate engine prices (~$200), and a 32v is available right now from an A8.
The 32v appeals to me (no timing chain tensioner/VVT) but I'm not set on it. If I understand correctly, the 32v has a 10 bolt flywheel so I would need to get an aftermarket one and a new clutch to match, I can't find any source for the engine mounts though or if there is a factory option. Edit: found old builds where the guy offered flywheels and engine mounts, but can't find current info on actually getting some.
Seems as though the 40v bolts up easier with factory/OEM sourced mounts, but would need a DBW conversion. Thought I read that I can use my existing 30v flywheel/clutch/pressure plate? I just replaced them so if I can re-use that would be great.
I did notice that I have a white plug that is going un-used in my ECU box, and I've read that the DBW harness has white plugs, so I'm not sure whats going on there since I'm non-DBW.
I would rather not sell my car and find a facelift version. Mine is super clean inside and out and I know the history etc.
So do I have this right?
32v:
-engine
-harness
-a lot of harness splicing
-aftermarket 10 bolt flywheel (edit: flywheel insert, see below)
-clutch/pressure plate to match (URS4/S6)
-aftermarket engine mounts or fabricate my own
40v:
-engine
-harness
-a little harness splicing
-DBW harness addition (can I keep my non-immobilizer gauge cluster?)
-DBW pedal cluster
-factory engine mounts
Oh, and is it easier to keep A/C with either swap?
Thanks guys.
