Results 1 to 9 of 9
Thread: Start-up issues
    Dec 24 2010
    2019AudiQ7
    DFW
    Start-up issues
    Started the car up last night, temp was ~40deg, had not been driven in 48 hours. 2004 with 90K miles.
    Symptoms -
    Hesitation at start-up
    Initial idle was ~500rpm for first 5 seconds
    Very minor shaking
    Ticking noise from engine bay
    Squeal / Whine sound (fuel pump?) prior to start-up
    NO check engine light
    Does this sound like a clogged fuel filter, bad fuel pump, or something entirely different?
    2016 S7 Prestige | Daytona GP | Black Optics | Sport Package | Carbon | DA |
    Mods : APR Stage 1 | Eurocode F&R Sways | 3M PPF | TAG Cosmetics |
    Senior Member Three Rings gregory.fazekas's Avatar
    Mar 09 2013
    2002 Audi Allroad, 2011 A6, 2004 B6 S4, 2015 Range Rover Evogue
    Lavallette / New Jersey
    Sounds like your fuel pump is on its way out, although I know these cars have timing issues. I would run a vag-com scan and see if any codes come up, then maybe start with a new fuel pump
    Current:
    2009 S5 6mt in Phantom Pearl Black
    FBO 2007 e92 335i 6mt m-sport
    FBO 2008 e92 335xi 6mt
    FBO 2008 e90 335xi 6mt
    Fully Bolted Nissan 350z 6mt
    B6 Stage 2+ A4 5mt
    Senior Member Three Rings Dirtracer603's Avatar
    Aug 15 2012
    Custom stunt CRF250 supermoto, 06 CBR600rr
    Fredericksburg, Va
    FYI. A clogged fuel filter will first show symptoms at WOT and as it clogs more you will lose the ability to put a load on the engine.
    Dec 24 2010
    2019AudiQ7
    DFW
    I'm going to take the car out to test symptoms across the spectrum of rpm and load conditions. I'll report back with results.
    Dec 24 2010
    2019AudiQ7
    DFW
    Started up 100% normal today. Ran a few errands, started and stopped normally 3 times in a 90 minute round-trip. Normal behavior in all rpm ranges. Any ideas on what kind of issue could come and go like this?
    Veteran Member Three Rings mistral cytz's Avatar
    Nov 13 2013
    Quote Originally Posted by AudiEmpire View Post
    I owned a Saab that had intermittent cold starting issues that ended up being a bad check valve in the fuel pump so fuel would drain out of the lines and it would take 5-10 seconds of cranking to regain fuel pressure and start followed by a rough idle.
    It could also just be something simple like bad gas or moisture in your fuel lines. Not sure how cold your temps have been this winter but leaving your car overnight repeatedly with less than half a tank of gas can cause ice crystals to form in the fuel system making the car difficult to start.
    2007 Ibis White S4 6MT Sedan. Fast Intentions 2.5" HFC downpipes and resonated catback, JHM Short throw shifter. JHM intake manifold spacers.
    Dec 24 2010
    2019AudiQ7
    DFW
    We have had some extreme temp fluctuations between a high of 65 and low of 18 in the 2-3 days prior to my issues, perhaps this was at least partly responsible. Thanks for your input!
    Senior Member Two Rings TheSchwa's Avatar
    Mar 08 2013
    B9 SQ5, 25quattro #99
    Bellevue, WA
    When was the last time you changed the spark plugs...?
    B9 SQ5 / Monsoon Gray / Prestige
    25quattro #99/250
    Dec 24 2010
    2019AudiQ7
    DFW
    Plugs were done at 77K in August of 2011 along with coil packs (under recall).
