Ok, hang in there while I attempt to describe what is going on with my B6 A4. I have a pair of Ziza LED plate lights from ecs tuning that are not working out well. I have the typical bulb out warning randomly wether they are working or not. Ok, here where I am lost. I sanded the contacts lightly to remove any corrosion, applied electrical grease and reinstalled. Works great! The next day they don't work unless I turn off the running lights and turn them back on. While driving down the road I get a bulb out light....EFFFF! So, I take them back out, bend the tabs up that allow them to make a solid contact and put the right one in, it works great. I go to put the left one in, it flickers and whenever I push it into place it causes the right side to quit. I put a volt meter on both sides and have 13 plus volts when it is running so I know I have power to the sockets. I checked continuity on the bulbs and it is also fine. So, I am lost lol I reinstalled the left one, turned off then turned back on my running lights and now the right one works but the left doesn't and no bulb out warning. I know both sides work well because I hooked a battery to each bulb and they are fine. Sorry If this was hard to follow but it is hard enough to understand when I am looking at it, let alone try to type it lol
