Originally Posted by
automatism
There is also a lot of slack in my gear shift ever since it has been fixed. My mechanic said so as well and he's worked on several s4s for comparison. I wonder if I've loosened something with my efforts to try to get the car to go in gear when the cross rod broke. I was able to get it into reverse a couple times but then it stopped doing it (but I didn't stop trying).
I thought the JHM part was supposed to be better. I'd have appreciated known this limitation before the install. I might install the short shifters at some point.
Audi/Vw has billions of dollars; I would think they could design a shifter better then anyone, which they have IMO. The stock shifter is butter, and doesn't look like giant Dong sticking out of the center console like every other car. This is the first car I've not Immediately torn the shifter out of when I got it home. When they designed the factory shifter/linkage they knew it would have to last at least 60,000 miles as well as not cause damage to the transmission during hard shifting. All those rubber's and Isolators on that linkage are there for a reason and I'm pretty sure they pay their engineers many times more then the dudes at JHM. Sorry, I'd never even heard of JHM untill I bought this audi and I've worked on eurotrash professionally now for 5 years; been in the auto repair/tuning business for 15 years total and when the previous owner was all "JHM this and JHM that", I was skeptical to say the least.
Then I saw what they wanted for a downgraded flywheel..Holey sh*t. There's 5 cent's worth of Alu/Steal. So you try and justfy 10,000% markup on material/labor/tooling with "R&D", then I find out they don't even build them!
The only thing I might ever consider is a trans/6th gear from them but even their Core policy is bogus. "If your core needs this and this, then we're adding that to the price of your new one" Suck a cock, if the the things in it weren't worn out I wouldn't be sending it to you.
BUT even with that: I do have full confidence in their trans building skills with these transmissions. partly because they're one of the few shops in existence anymore that will even open one up. From what I have seen they keep it in-house and have a working knowledge of the transmission, more then anyone else I could find.
Ill keep the stocky Shifter =)
