Results 1 to 13 of 13
    Veteran Member Four Rings clumsyme's Avatar
    Jun 12 2013
    Nashville
    Non-Bose system only sound out of 1 speaker
    Hey guys so here is the problem I am having is I got a new oem radio to replace the old destroyed one that came with the car. I figured that it was the radio causing my issue but I put the new one in and I still only get sound from the passenger rear speaker and it sounds very weak. Help me
    "He-Man with that long sexy hair, in those provocative tights with his butt looking oh so scrumptious in those booty huggers." -Seerlah
    Aug 01 2013
    Melbourne, Australia
    Do you have vagcom? That will show errors if any speakers are blown or disconnected.
    From memory one of the rear speakers in mine was disconnected and it broke the circuit for the other. If you have a sedan you can check the rear ones are connected pretty easily.
    Sent from my HTC_PN071 using Tapatalk
    Jun 12 2013
    Nashville
    Quote Originally Posted by Strangelove View Post
    I have an avant and I hooked it up to VCDS over the weekend and it didnt throw anything from the general scan, is there a certain section I should go to for that
    Aug 01 2013
    I think it should pop up in the general scan. I had a blown speaker that registered. I would have thought any broken circuit would appear too. We might have reached the limit of my knowledge sorry.
    Jun 12 2013
    Nashville
    Thats totally fine. I am so far over my head. I do suspension not sound. haha
    Active Member One Ring Turbo_mike's Avatar
    Feb 26 2014
    99.5 a4 1.8tmq
    ohio
    My sedan(non bose) had your same problem, bought the car with a blown radio swapped it out with a new one and the deck speakers weren't working. I found out the amp from the left speaker was missing, its like a metal square box mounted under the left speaker. I'm almost positive non bose rear speakers are powered by an amp. if i was you i would find that amp.
    Jun 12 2013
    Nashville
    I figured out my issue!!!!! I bought a radio that was from a bose car and mine isnt. I got the front speakers going saldy my laptop died before I got everything set with vcds. BUT my front driver side speakers are blown so I need to head to the PNP and grab some
    Feb 26 2014
    99.5 a4 1.8tmq
    ohio
    CHEERS!!! glad you figured it out, i replaced my front speakers with 5.25" rockford fosgate punch series. sound a hella lot better then oem!!
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Don't even bother getting OEM speakers.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Jun 12 2013
    Nashville
    alright then the next question I have is what are good options that will plug right in for the OEM ones? Sorry this is one area of cars I have no clue about
    Jun 12 2013
    Nashville
    Yay new issue. So I got the radio reprogrammed and now the rears don't work. But I know they aren't blow because that was the one speaker that worked before. So my question is I vcds what should the code be for a car with non Bose should the rear speakers be set to passive or active?
    Jul 27 2011
    IN
    I don't understand why you guys are still sticking with those 13+ yr old speakers.
    Jun 12 2013
    Nashville
    I don't want to stick with oem. But I have a nice 6 hr drive coming on Monday and would really like some music. So I am looking for a decent fix for now.
    I have an avant so I am going to have to tear up the rear drive side to try and find the amp and the sub. But is there another amp on the rear driver speaker?
