Results 1 to 23 of 23
    Veteran Member Four Rings Firefox250's Avatar
    Nov 17 2009
    BT B7 A4 Sedan Quattro & B7 A4 Avant Titanium 2.0T Quattro
    Aurora, Colorado
    Miro 111 19x8.5 ET32 issues
    Edit: Apparently I just have wheels that are different or my rotor "hat" is short so I'm just going to grind off some of the caliper.
    Tuned by UNITEDMOTORSPORT
    HTA3073 Build page
    Bluewaters Performance blog on my build
    If they were cone seat, I'd be all over this.
    2008 B7 2.0T Quattro 6MT
    Sold:
    2013 VW CC R-Line
    2005 B6 1.8T Quattro 6MT
    RIP:
    2002 B6 1.8T - April 2019
    2004 B6 3.0 - August 2018
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    thats weird...doesnt seem right
    Nov 17 2009
    Aurora, Colorado
    I was hoping to hear from anyone who is running Miro 111's.
    Sent from my SM-T310 using Tapatalk
    HTA3073 Build page
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    maybe you got a bad batch?
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2017 Mitsubishi Outlander GT
    Otterburn Park, QC
    I dont have issues with my 18". But i am running S4 discs, that bring the caliper away from center.
    Owning an Audi is like having a hot girlfriend that's mentally unstable
    2013 Allroad sport pkg, 19" gold Radi8 r8s5, B8 Sline suspension, AEM air filter, more to come...
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    i would definitely hit them up. et32 shouldn't be a problem...
    Nov 25 2011
    2018 F80 M3 ZCP, 2007 RS4
    Thats very odd. I run the 111's 19x9.5 et40 rear and 19x8.5 et32 front. They clear my brakes by a good amount.
    Nov 17 2009
    Aurora, Colorado
    Quote Originally Posted by AJacksA4 View Post
    Yeah exactly I don't understand the wheel is an ET32! At minimum I would need a ET35, but its scraping the back side of the wheel as you see in the picture. Would you mind taking a picture of your brake caliper clearance?
    The only part that is not stock, is my rotors that are power slots. I'm going to take off the wheel tomorrow and just check for the stamp inside the wheel to make sure its a ET 32.
    HTA3073 Build page
    Nov 25 2011
    It must be your rotors then. The hats are probably a few mm thinner than mine. I am running Adam's rotors though.
    Nov 17 2009
    Aurora, Colorado
    Stupid brakes.
    Thank you, that's an easy fix with 5mm spacers. I just hope the fender rolling will help, and I might have to raise my ride height.
    You know after zooming in your brakes the clearance, it looks like your wheel just barely scraps the caliper because the sticker has scratches on it.
    HTA3073 Build page
    Nov 25 2011
    Quote Originally Posted by Firefox250 View Post
    Stupid brakes.
    Nope thats just brake just. Trust me I have about 3-4mm of clearance. What tire size are you running?
    Nov 17 2009
    Aurora, Colorado
    245/35R19
    I just put on a 5mm spacer and now I have clearance but massive poke.
    HTA3073 Build page
    Nov 25 2011
    I think you should try grinding down your calipers a bit. Running em like that you could burn the paint off the edge of your fenders (some dont care tho, all about the show). I run 235/35/19 in the front and have zero rubbing. I just removed the 12 o'clock screw.
    Established Member Three Rings V2Rider's Avatar
    Feb 11 2014
    2011 Jeep Grand Cherokee, 2007 Audi A4 2.0T Quattro, 2006 GSXR 750 (very fast ) :)
    Minneapolis, MN USA
    For sure under suspension flex, ^ he will be rubbing.......
    2007 Audi A4 2.0T Quattro TIP /Debadged/Piston DV/Hids/APR Stage 1 AMSOIL
    Nov 17 2009
    Aurora, Colorado
    Grinding down the calipers sounds like my best option. I just need to take off 1-2mm. I went with the 245 because I wanted to run the correct tire load rating. The 12 o'clock screw has been removed also.
    HTA3073 Build page
    Nov 15 2011
    Montreal | I sell in USD
    Mexipoke will cause paint flaking for sure if not worst
    *****I sell in USD*****
    Veteran Member Four Rings B7Joe's Avatar
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    Quote Originally Posted by Axis View Post
    Mexipoke?
    Nov 15 2011
    Quote Originally Posted by B7Joe View Post
    Mexipoke?
    The poke will cause paint flaking if not worst.
    The mexipoke was an exageration, but if your question was : "What is Mexipoke?" Here's a picture:
    Poke:
    Mexipoke:
    Nov 17 2009
    Aurora, Colorado
    Edited first post.
    HTA3073 Build page
    Nov 17 2009
    Aurora, Colorado
    Whelp the grinding worked. The wheel clears now. Woo-hoo!!
    Now I just have to repaint the calipers.
    HTA3073 Build page
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    yay! so we'll see you on saturday.
    Nov 17 2009
    Aurora, Colorado
    I'm going to try I need the fenders rolled still.
    HTA3073 Build page
