Results 1 to 2 of 2
Thread: Oil leak help!
    Veteran Member Four Rings italia8287's Avatar
    Jul 23 2008
    New York
    Oil leak help!
    Can't tell where I'm leaking oil from. Here are some pictures, hope you guys can help!
    [IMG][/IMG]
    [IMG][/IMG]
    Also, I've already had the vacuum pump replaced. I don't think oil usually leaks out from the head gasket, but that is my assumption.
    Thanks guys!!
    2007 QMT6 Ti S-Line
    NorthEastRegionDubs
    Established Member Three Rings V2Rider's Avatar
    Feb 11 2014
    2011 Jeep Grand Cherokee, 2007 Audi A4 2.0T Quattro, 2006 GSXR 750 (very fast ) :)
    Minneapolis, MN USA
    ^looks like mine did when I forgot to drain the filter housing before removing it
    Spray degreaser all over that area, clean it up, and drive it, check it right away to minimize the location
    2007 Audi A4 2.0T Quattro TIP /Debadged/Piston DV/Hids/APR Stage 1 AMSOIL
