Results 1 to 6 of 6
    Established Member Two Rings mr_pulido88's Avatar
    Jul 02 2013
    Antelope Valley
    Is there a way to know which DV revision I have installed?
    I bought a '07 A4 2.0T with 100k miles last July and I'm trying to fix/upgrade the parts that need to be upgraded.
    Is there a way to know if the diverter valve is the latest revision?
    Do I have to just take it out and check for any codes or part numbers?
    Oct 16 2008
    South Florida - Ft Lauderdale
    All revisions look the same from the outside, except the PN stamped
    To be sure, pull it off
    Phil
    Jul 02 2013
    Antelope Valley
    Phil
    Alright, will do. Thanks Phil!
    2007 Audi A4 2.0T Dolphin Gray S-line
    "God has put obvious limitations on our intelligence; but none whatsoever on our stupidity"
    Senior Member Three Rings SwiftA4's Avatar
    Aug 20 2012
    I agree with Phil, but if you don't want to pull it off, since it's a b**** lol, you'll be able to see the part # on the DV. You really just need to see the last letter of the part # which is easily visible. Look right above the wiring harness.
    2008 A4 S-Line | APR Stage 1 93 | Ibis White | 2.0T Quattro Tip | Koni FSD/Eibach | Debadged | R8 Coilpacks | BKR8EIX | OEM Roof Rack | VEI/Podi | 15% Side, 5% Rear | Rev. "D" DV | 034 Snub |
    Retrofits: S4 Power Folding Mirrors | Warning Triangle |
    Jul 02 2013
    Antelope Valley
    Quote Originally Posted by SwiftA4 View Post
    Oh cool, I didn't wanna take the whole thing off just to look for a number lol
    Just to be sure, the last letter should be "D", correct?
    Aug 20 2012
    Yep. When you are looking at the DV from under the car, the part # will be stamped on the drivers side of the DV, right above the electrical harness. It will also be upside down lol. But you'll be able to clearly make out the last letter just by rubbing some of the dirt build up off it.
