Results 1 to 12 of 12
    Veteran Member Four Rings VJ's A6's Avatar
    Jan 23 2007
    2000 TL; 2002 GMC 1500 Pickup
    2012 3.0T Ibis SLine
    I am have been on AZ for a while mostly on C5 A6 forum. I really wanted and Ibis Sline TDI and couldn't find good CPO one after searching for about a year, so gave up the TDI and got a 3.0 T instead. Absolutely love the truck.
    I am debating these changes not sure if I pull the trigger because my wife drive this one daily
    The List:
    Tint Front Windows
    Wheels powder coat GUNMTEAL
    Calipers power coat Brembo Red or Orange
    Exhaust tip GUNMETAL
    Spacers
    APR Stage 2
    -Koni's / H&R Sport -Hotchkis Sway Bar F+ R - 2.5 Inch Custom DP's - 2.5 Inch Magnaflow Exhaust -LED Tail Lights -S6 Door Blades -Valentine V1 -35 % Tints All Around
    Veteran Member Three Rings robsilvr85's Avatar
    Nov 23 2005
    17 Volvo XC90 T8, 05.5 A4 2.0TQ
    Chicago
    Nice! What size spacers are u looking to get?
    05.5 A4 2.0TQ
    - JHM Stg1, DV, 18 Peelers
    11 Q7 TDI Prestige
    - 22 Ace Convex
    Veteran Member Four Rings rayray's Avatar
    Sep 17 2010
    ‘19 S5/SB; ‘17 Q7
    Massachusetts
    Very nice! Congrats! The 3.0T is plenty with that supercharger on it.
    2019 S5 Sportback Prestige | Daytona Gray Pearl on Black | Black Optics | S Sport Pkg
    2017 Q7 3.0T Prestige | Ink Blue Metallic on Nougat Brown | Driver Assistance Pkg | 21"RS Wheels | Towing Pkg
    Jan 23 2007
    Quote Originally Posted by robsilvr85 View Post
    15 mm front and 20 - 30 mm back.
    APR Stage 2
    Jan 23 2007
    Quote Originally Posted by rayray View Post
    For a SUV it really moves. My only complaint is body roll, I wish there is an upgrade of it other than KW V3 coil over.
    APR Stage 2
    Sep 17 2010
    ‘19 S5/SB; ‘17 Q7
    Massachusetts
    Quote Originally Posted by VJ's A6 View Post
    There are springs and sway-bars out there that will help. IMHO, its body roll is better than other SUVs in its class.
    Jan 23 2007
    Do you know how makes sway-bars for Q7's? I don't want springs because of CPO warranty and I really like the ride comfort.
    APR Stage 2
    Sep 17 2010
    ‘19 S5/SB; ‘17 Q7
    Massachusetts
    I was told this one works since there are no structual changes between the years.
    http://www.speedshopstore.com/suspen...2007-2010.html
    Established Member Two Rings clover168's Avatar
    Jan 27 2011
    calgary
    You can also use cayenne sway bar. Any suspension components can be use in q7.
    Sent from my SGH-I317M using Tapatalk
    Jan 23 2007
    ^^ thanks for the links guys. I will check it out.
    Anyone here installed these? I want to get some feedbacks before buying it.
    APR Stage 2
    Senior Member Two Rings R-Tic's Avatar
    May 26 2004
    Various parts from Audi that resembles an A4 and now a Q7
    St. Louis, MO
    Love the Ibis Q7...been looking for years for a great deal...finally got a 2008 with 40K miles plus 100K warrenty...Lava Gray...the wife loved it so SOLD....
    Anyway, just starting looking for SWAY bars and think the Touareg and the Cayenne interchange with the Q7. Been looking at multiple postings and not finding what I want or responses to anyone that has done....also a DIY would be great....
    I'll post what I gather and hopefully keeping this thread going will bring more responses....
    May 26 2004
    St. Louis, MO
    Got this from a 2011 thread URL: http://forums.audiworld.com/showthre...=rear+sway+bar
    this is a good start..I am looking for rear upgrade on a non air suspension. I will focus on this for now.....
    Front Bars Options:
    ??????????? / ??????????????? = 34.6mm x ??.?mm (white) - Stock V10 Touareg Air Susupension
    ??????????? / ??????????????? = 35.6mm x ??.?mm (colour?) - Stock V10 Touareg Steel Susupension?
    7L0411025E / 955-343-701-50 = 37.0mm x 5.2mm (yellow) - W12 Sport Touareg, Cayenne TT
    ------------- / 955-343-701-60 = 38.0mm x ??mm (orange) - V6 Cayenne No equiv Touareg.
    ??????????? / 955-343-701-70 = 38.0mm x ??mm (green) - Cayenne S w/ Steel Suspension
    ??????????? / 955-343-701-80 = 38.0mm x ??mm (brown) - Cayenne GTS w/ steel suspension
    Rear Bar Options:
    7L0511025B / 955 333 701 20 = 24.6mm x 3.6mm (lilac) - Stock Q7 Air Ride, V10 Touareg
    7L0511025C / 955 333 701 30 = 25.6mm x 4.4mm (yellow) - Cayenne TT
    7L0511025 / 955 333 701 00(?) = 25.0mm x 4.?mm (green) - W12 Sport Touareg, Q7 V12 TDI, Cayenne S w/ Steel Suspension
    STOCK Q7 FRONT SWAYBAR SETUP INFO:
    With air suspension; ??.?mm, colour, pn: ???
    With steel suspension; ??.?mm, colour, pn ??
    STOCK Q7 REAR SWAYBAR SETUP INFO:
    With air suspension: 24.6mm, lilac, pn: 955 333 701 20
    With steel suspension; ??.?mm, colour, pn: ??
    UPGRADES:
    Yellow Cayenne TT bars are a good bet for those that want off road and on road combination performance. These bars may be way too thick to allow articulation for any serious off-roading.
    FOR NON-AIR-RIDE Q7/TOUAREG:
    Front Sway Bar - Cayenne S - Part # 955 343 701 70 <-- 38.0mm sway bar (green)
    Front Bushings - Cayenne S - Part # 955 343 792 61 (4 needed)
    Rear Sway Bar - Cayenne S - Part # 955 333 701 00
    Rear Bushings - Cayenne S - Part # 955 333 792 40 (4 needed)
    FOR AIR-RIDE Q7/TOUAREG:
    Front Sway Bar, Cayenne TT: Part # 955-343-701-50 <-- 37.0mm diameter (yellow)
    Front Bushings: 955-343-792-50 (4 needed)
    Rear Sway Bar, Cayenne TT: 955-333-701-30 <-- 25.6mm diameter (yellow)
    Rear Bushings: 955-333-792-30 (4 needed)
