My car's(98 AEB FWD) idle automatically increases at times, so was looking for vacuum leaks and found a crack on the valve housing(item 5 in the parts diagram) in the PCV line below the intake manifold.
I was about to get a new T- valve housing, then got confused by the parts diagram. Where is the bleeder valve(035103245A-item 6 in the parts diagram) located exactly? Is it inside that T-shaped valve housing? Because, when I looked at my car I didn't see a bleeder valve in front of the T- shaped thing as shown in the parts diagram. All I see is a hose coming out of it which is then going to the top of the intake manifold. Now am confused where is this crack exactly...
Am I interpreting things in the wrong way here? Any help would be appreciated..
