Results 1 to 9 of 9
    Jun 16 2009
    Houston
    Another for the B8 A4 Avant regime
    After getting my ECU sorted my air ride install was completed this weekend. I'm loving it so far. I would like to get the front down a bit more though.
    Airlift bags front and rear
    2 440cc Viair compressors
    4 Gallon tank
    Accuair E-level
    The only outstanding issue is I have one sensor not connected because the actual connector is broke. Are these easy to come by? I'm guessing accuair could send one but I just haven't called yet. So everything is manual right now until I get the connector.
    Aug 19 2013
    Glendale, AZ
    Looks great! Are those 19's or 20's? AccuAir sells all kinds of parts and pieces. They'll take care of you for sure.
    Jun 16 2009
    Houston
    Thanks. They are 19x10 all around. Yeah I called them and I should have the connector Wednesday.
    Veteran Member Four Rings gohan's Avatar
    PA
    very nice! i see everything fit in the wheel well. what tire size are you running?
    Sent from my SCH-I605 using Tapatalk
    2010 B8 Avant - Aired Out - Gone
    2003 B6 Sedan - Gone..
    Jun 16 2009
    Houston
    Quote Originally Posted by gohan View Post
    Thanks. I'm running 245/35's all around.
    Established Member Two Rings furleeA4's Avatar
    Feb 08 2007
    san diego
    Looks good! Set up pricey?
    Apr 24 2013
    Canastota, NY
    Also curious about price -all in (gear & installation)
    Veteran Member Four Rings a408's Avatar
    Nov 06 2008
    Orange County, CA
    Quote Originally Posted by furleeA4 View Post
    Quote Originally Posted by MaXaZoR View Post
    MSRP on the Accuair E-level B8 Sport kit is $4850 and includes everything you need to get on the ground. With the upgraded dual compressor, power supply kit, and all of the hardware/brackets needed to make it a full bolt on kit. Very well worth the money.
    @Boden_AutoHaus
    2021 Merlin Purple RS6 Avant
    2021 Grigio Scuro F8 tributo
    2020 Aston Martin Vantage
    Apr 24 2013
    Canastota, NY
    Thanks Josh
    Love your rim choice...I'll be posting up my B8 Unicorn soon.
