Results 1 to 4 of 4
    Nov 13 2012
    Stock Offset on A4 allroad??
    Does anyone know the exact offset on the 2013 A4 allroad 17" wheels? I am looking to put my stock 19" peelers from my S5 on the allroad which are a 32 offset and wondering how it will look and if it will look better with spacers or without. The allroad is at stock height for now and not lowered.
    Sep 24 2010
    Irvine, CA
    Does the new Allroad come with 17" in Canada?
    My '13 Allroad comes with 18"x8s, and the off-set of the 18"s is ET26.
    Nov 13 2012
    Yeah, 17" was the only wheel size in the color combo that I wanted and was available locally at the time, White on Chestnut Brown. I knew after the winter I would be swapping out the wheels and keeping the stock 17"s for winter so went for it but now can't seem to see the stock offset??
    Aug 18 2009
    A Unicorn
    Portland, OR
    Pop off a wheel and check. It'll be stamped right on the back of one of the spokes. That said, the width of the wheels also comes into play. That is to say that et33 (S5 peelers are 33, not 32, not that 1mm makes a difference) on your 9" wide peelers is the same as et 33 on a 7" wide wheel, or 8", etc.
    Use something like this: http://www.willtheyfit.com/ or this http://www.1010tires.com/tools/wheel-offset-calculator to calculate the differences between the two
    :: Seller feedback ::
    RIP: 2006 DG Avant Tip
