Results 1 to 39 of 39
    May 18 2007
    golden, co
    Satin Black dash trim
    After the trajectory of yesterday's emblem idea thread, I hesitate to post this, but I painted my dash trim this weekend and I think it turned out well. I know many people don't like all that aluminum around the gauges so I wanted to post this in case anybody else is thinking about trying something similar.
    It's a very simple, inexpensive, and completely reversable.
    1. I pulled the trim off and wiped it very clean with lacquer thinner. DO NOT scuff it up. The paint will adhere fine and the trim remains pristine in case you want to reverse course.
    2. I then masked off the indented area around the MMI screen. I have seen others paint the trim entire trim piece but I thought it would look better to retain some bare aluminum around the MMI screen. I like the way it turned out.
    3. I sprayed it with 2 heavy coats of Satin Black enamel from Home Depot.
    4. I finished it off with OSIR trim pieces to provide a bit more contrast around the gauges.
    I like the way it turned out and again, pretty easy and completely reversable. If you don't like it, just wipe it clean with lacquer thinner and you can go right back to the stock look.
    Flame suit activated...
    Active Member Two Rings mungo513's Avatar
    May 14 2013
    Bridgewater, MA
    I like it. I've been planning on doing mine. Think I'm going to the whole thing black. I like those two pieces. Hadn't seen them before. How much did those run?
    Sent from my SM-N900V
    2018 SQ5 Prestige | Billet Silver Metallic
    2011 S4 | APR Stage 2 | Quartz Grey Metallic (long gone...)
    Veteran Member Three Rings chrisbryan89's Avatar
    Apr 01 2012
    GSXR 600, B8 S4
    Portland, OR
    I think it looks great for such an inexpensive solution
    Daily: B8 S4 - Ibis White
    Sold: B8 A5 - Brilliant Black
    Toy: 2011 GSXR 600 - Black
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    This actually does look good. I think what makes it is the Alu trim on either side of the cluster.
    Senior Member Three Rings Moto One's Avatar
    Mar 26 2010
    C5 Z06 (going on 17 years)
    Tahoe/Truckee
    Nice work.
    Mark
    Oct 02 2013
    Redstone, CO
    Holy shit man, well done!! I've seen a few of these on here and I think your's is comfortably the best I've seen. How well do you suppose that will hold up?
    Nice work!
    2014 S4 Estoril Blue, Black Opt, 19" Rotor, Side Assist, Carbon Inlay, B&O Sound, MMI/NAV, Rear Camera, Advanced Key, Supercharged badges, H&R OE, Track+ Spacers, 10/15mm, otherwise stock.
    Senior Member Two Rings salyaqout's Avatar
    Dec 22 2013
    1970 Dodge Challenger 340 - 2013 Audi A1 - 1981 Toyota FJ40
    Kuwait
    Fantastic work.
    2013 Audi S4 (DSG) Imola Yellow- Milltek Exhaust Non-Res (oval) , H&R Street Coils, AWE S-FLO Carbon intake , RS5 BBKs, E-Code Sways, 70% 3M Crystline
    S(aud) alyaqout
    Veteran Member Three Rings fritze18's Avatar
    Mar 12 2012
    2013 Audi S4 Premium DSG
    Ontario, Canada
    Turned out very well. I really like the contrast with the silver portion that you left. Good job
    Current: '13 S4 Premium S-Tronic w/Sport Diff -Glacier White
    AWE Exhaust w/Res DP|USP Intake|Podi Boost Gauge|20% LLumar Tint|LED Interior|RS4 Grille|H&R OE|Bilstein Dampers|AG M510
    Former: '11 A4 2.0T Quattro S-Line 8-Spd Tip "30 Years of Quattro Edition" -Daytona Grey
    AWE Dual Exhaust|AWE Intercooler|STaSIS ECU|EC TIP|AFE Dry-Flo Filter|EC Intercooler Hoses|EC HFIP|AWE Boost Gauge|LED Interior/LP|H&R Sports|Rieger Rep Spoiler|20% LLumar Tint|RS4 Grille|Xenon-Match Fogs
    Oct 14 2012
    Empty...for now...
    SE PA
    I like it....a lot. I'm going to copy this.
    Exactly which paint did you use?
    EDIT: Looking closer at your pics, I'm wondering how you were able to get such a clean line around the MMI surround area. Masking is one thing, but your color cut-off looks razor sharp. Any closer up pics or tricks/tips?
    SOLD 2015 Daytona Gray S4
    Senior Member Three Rings chet's Avatar
    Nov 29 2012
    2011 Jetta Sportwagen TDI, 1984 Volvo 240 DL Wagon
    SF Bay Area
    Another +1! You can take the flame suit off. :)
    Sent from my Nexus 5 using Tapatalk
    2013 S4 Prestige / Revo Stage 1 / Milltek non-res / Stoptech ST60 380mm / H&R OE Sport / Alu Kreuz / 034 Control Arms
    Sep 28 2010
    NW NC / DE
    I very much like it!
    May 18 2007
    golden, co
    Thanks for all the compliments.
    I think it should hold up. It feels like a pretty thick, hard coating...plus that's not exactly a high traffic area.
    Just good old blue masking tape, a really sharp razor blade, and a little patience. For the most part, you can run the tape line right along the top edge of the bevel (if that makes sense). The only place you need to trim are corners. My technique was to apply the tape across the corners, push it into the bevel as much as possible, then run the razor horizontally along the surface above the bevel...I'm not sure that make sense but it really is just about being patient. The edge did turn out good but if you look close, it's not perfect in a couple of spots.
    Another thing you could try for the edges would be to finish them off with some 1/16 or 1/8 pinstripe tape. I have done that in other instances and it works well. The only downside is that I've never seen Satin black tape, only gloss black, so you would have a slight variation in the satin paint and the glossier stripe around the edges. I think it would probably look fine though.
    Good luck.
    Active Member Two Rings ajpuleo23's Avatar
    Jan 16 2013
    Bel Air, MD
    I think it looks great actually. Flows with the silver and rings in the wheel spot on. Might have to do this myself. Thanks
    '10 S4 | P+ | Quartz Grey | Sports Diff | Black Nappa | Carbon Inlays | carbon SC badges | 3M 30% ceramic tint | full LED interior | RS Grille | 3K HID Fogs | subject to change...
    May 16 2008
    WA
    Leaving some of it exposed was a great idea. By doing that, it gave a nice balance to the end result.
    Looks like you laid that paint down buttery smooth too
    Established Member Three Rings LakeShow's Avatar
    Apr 26 2013
    Long Island, NY
    Looks great! Blends in for sure
    2013|S4|Carbon Atlas|MMI 3G+NAV|Supercharged Badges|3M 35% Tint|Gloss Powdercoated Peelers|AWE Tuning 102MM|Roc-Euro|Vag-Com'd|
    2014|C63 AMG 507|
    IG: _LakeShow_
    Oct 02 2013
    Redstone, CO
    If I lived in CO, I'd pay you 5 bucks to do that to my car! I'm jealous.
    Dec 23 2013
    New York
    sexy
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by chanceparker View Post
    Good luck.
    I painted the entire trim on my 2010 with satin black Rustoleum. But I used the "universal " spray paint . Wasn't sure how it would hold up but i had no issues. IMHO, the Satin finish blends well with the other black pieces in the interior.
    Veteran Member Four Rings catch's Avatar
    Feb 17 2012
    GTA
    looks good!
    I would have gone glossy to match the panels below though
    Jan 10 2007
    VA
    The B8 the panels are regular black plastic. B8.5s have all the glossy black touches.
    Quote Originally Posted by catch View Post
    looks good!
    Jan 10 2007
    VA
    Definitely looks good, but I think it would be cleaner if the indented MMI portion was also painted black.
    May 18 2007
    golden, co
    I have seen a few done that way and I think it's too much black, but that's just my taste.
    IMO the ideal would be just a metal "ring" around the MMI screen like on the left-most air vent, but that's beyond my abilities.
    Jun 28 2012
    North NJ
    Came out nice. I've been meaning to paint mine since last summer and never got around to it
    2012 S4 Prestige - Ibis and Titanium - 6MT - MMI - B&O - Rear Parking - Advanced Key
    - Clear Bra - Vag Mods - 8500 Hardwire - Intercooler Screen - Roc-Euro Short Shifter - Eurocode Rear Sway Bar - CR-15 - Matte black rear valence - Show N Go Front Plate
    1991 Ducati 851 - 888cc High Compression Pistons - Big Valve Corsa Heads - High Flow Fuel Injectors - Open Airbox - Braided Steel Lines - Corbin Seat - Fast by Ferracci Chip and Mufflers - Carbon Fiber bits
    Hex-Can-USB in Northern NJ
    Active Member One Ring Nels2012's Avatar
    Feb 14 2014
    Las Vegas, NV
    Looks very nice, the amount of silver in my all black interior has always bothered me a little.
    Jan 10 2007
    VA
    Yeah, I didn't realize the upper dask trim on the B8 and B8.5 were different.
    On the B8, its all sliver. On the B8.5 there is much more black around the screen and hazard button as well as a metal 'ring'. Also just noticed the B8.5 has metal trim around the guage cluster whereas the B8 does not.
    So if you had B8.5 trim, you could black out the silver and be left with just the metal ring as you mentioned.
    Oct 14 2012
    Empty...for now...
    SE PA
    Any tricks or tips for removing the dash trim without causing any damage?
    May 18 2007
    golden, co
    Except B8.5 trim won't fit in a B8. That was my first move but it won't work.
    Just start from the bottom with a flat screwdriver and go slowly. There aren't very many clips so you should be fine. Also note that the trim ring round the left vent is a separate piece and will likely fall out and give you a panic attack:)
    2012 S4 | Glacier White/Titanium Pkg | Magma/Black/Atlas Carbon | 6-speed | OEM Rotors
    May 16 2008
    WA
    wouldn't a cheap trim removal tool be better than a screwdriver, as to prevent denting, nicking, or marking anything:
    http://www.harborfreight.com/5-piece...l#.UyM464U-cw4
    May 18 2007
    golden, co
    If you want to spend the extra $. Trust me, you can do it with a regular screwdriver with no issues.
    Oct 14 2012
    Empty...for now...
    SE PA
    I gave this a try this weekend and the results are so-so. I masked off around the MMI screen area just like yours, but the line that I have is very rough, even on the parts where the masking tape was straight. It almost looks like little bits of the paint came up when I pulled off the masking tape. Any tips for this?
    May 18 2007
    golden, co
    A couple of things to try:
    1. Make sure that you have wiped the trim pieces down very well with lacquer thinner before painting them.
    2. Maybe try pulling the masking tape off before the paint is fully dry, when it's still just a little tacky.
    If neither of those work, then I would try using pinstripe tape to mask the break line (then us regular tape to complete masking off the trim).
    Hope that helps.
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Not bad brother. You may have explained this and I missed it, but why go with the paint over something more easily removed like plasti-dip?
    l Previous: 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l 2025 Rivian R1S Tri l Midnight/Dark Mountain l XPEL Stealth Wrap l
    May 18 2007
    golden, co
    Plastidip doesn't match the OEM soft-touch black paint on the center stack as well...too much texture and a little too flat. That's the only reason as I have used Plastidip in plenty of other applications and it works great.
    Apr 04 2012
    MSP
    Anyone have these on the OE silver trim? Wonder how it would look...
    http://www.osirusa.com/mm5/merchant....ry_Code=S4B8IA
    Edit: Reason for the question - I have a set sitting in my garage I was going to use with a black Piano trim set I was hoping to buy. The vendor went dark on me and I never ended up buying the set - but now that I think about it I think they would look nice even with the silver trim. I've lost interest in painting or swamping the trim for black - silver is fine for me... I'll stick them on and post some pics for anything interested in seeing how they look...
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    I've been wanting to do this but will most likely wrap it so I can go back to stock if I trade up.
    May 18 2007
    golden, co
    It's paint...you can take it off with lacquer thinner if you want to go back to stock. That's exactly why I didn't scuff up the trim prior to painting it.
    Your link doesn't work.
    Apr 04 2012
    MSP
    Ops...
    It's the same trim you have - http://www.osirusa.com/mm5/merchant....ry_Code=S4B8IA
    Oct 14 2012
    Empty...for now...
    SE PA
    Hope that helps.
    Thanks for the feedback. I thought about pulling the tape off before the paint was fully dry, but ultimately decided I would likely accidentally touch some other part of the wet paint in the process so it was better just to wait.
    I did a thorough wipe-down with lacquer thinner and let it air dry a bit before painting, and adhesion seems to be good. Before I get into stripping it off and trying again, I'm going to try carefully scraping along that edge to see if I can even it out. I actually did one little spot with my fingernail (gross, I know) and that seemed to work pretty well. Smoothed it out enough so that I could barely see the imperfection from the driver seat.
    My Osir silver trim pieces should be here on Wednesday so hopefully I can get it cleaned up before then.
