Results 1 to 13 of 13
    Mar 03 2014
    United States
    crankcase breather hose missing 1.8t
    Ok so i have a 2001 a4 1.8t with 197xxx miles on it. And while i was under the hood replacing the plugs and coils i noticed a big hole below the dip stick. I think its the breather hose but im not sure. I have no idea how long it has been off. How significant is it to have been missing like it was. Also how do i go about putting a new one back on?
    Dec 05 2007
    Spend the money on the 034 kit and never worry about it again.
    http://store.034motorsport.com/breat...-silicone.html
    Sep 03 2009
    San Antonio, TX
    Second that!
    OEM one =
    Although I would keep shop vac ready for when you disconnect the oil filter adaptor part. It's a plastic covered metal sleeve and there's a 95% chance that it will turn to confetti before you get it out and fall into the OFA. If you get a good seal with the vac on the opening, you will be able to suck all that crap out of there.
    MY BUILD
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    I emulate this. Let this be a lesson for you: A while back I decided oh, it will be a cool idea to just dump it to the ground to reduce some clutter. Turns out that ended up causing excessive crankcase pressure so I decided to return back to stock pcv system. Yea.. I was able to piece together the oem setup (stupidly threw away all my old parts) including the hard pipe off eBay, the two valves and all associated piping for less than the oem pieces. I saved about $50 dollars or so but didn't recieve everything at once because I was price shopping, so that was a frustration. I would buy the 034 kit if I did it again. Part of me still wants to buy the 034 just because.
    Veteran Member Four Rings pbcrazy's Avatar
    Feb 06 2013
    VA
    Quote Originally Posted by Believer View Post
    It's a great kit. Looks better than stock, makes the valve cover and coolant flange so much easier to do, and will never need replaceing. For the extra ~$50 over oem it was 100% worth it and more
    98.5 Audi A4 1.8T Quattro | 5 Speed | AEB | Laser Red
    | FrankenTurbo F21L | United Motorsports Stage 3 | 630cc Injectors | 3" MAF | ICM Delete w/FSI Coils | Scorpion 2.5" Catback/RAI 3" Test Pipe | Forge 007 | 034 Silicone PCV | Alzor 349 | FMIC | ECS RA4 LWFW/S4 Clutch/S4 P.Plate | AEM | Krauto | etc.
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    Yep, can't go wrong with the 034 piece.
    Here's my DIY on installing it: http://www.audizine.com/forum/showth...on-AEB-(early)
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
    Mar 03 2014
    United States
    if i do replace the hose just with oem will i notice a increase in anything? and would just leaving it off cause any problems in the future?
    Feb 06 2013
    VA
    Definitely replace it all, you won't notice an increases but your belly pan will no longer be covered with oil
    Veteran Member Four Rings ray4624's Avatar
    Nov 27 2010
    mass
    are you sure there wasnt another issue? This would mean that everyone running a catch can is going to blow a headgasket.
    Oct 24 2011
    New Jersey
    Quote Originally Posted by ray4624 View Post
    I didn't say anything about blowing head gaskets. I was getting pressure coming out from my new oil cap. Replacing the PCV system has eliminated that issue.
    Nov 27 2010
    mass
    thats real weird.
    increased crankcase pressure can lead to a blown hg it was just an exaggeration.
    good that you fixed it though.
    Oct 24 2011
    New Jersey
    thats real weird.
    I suspect I have increased blow-by due to age and that the cold temperatures aren't helping. I have observed that i don't pull the strongest vacuum until the engine is fully warmed further suggesting rings. Either way I'm sourcing a short block to rebuild now
    Ryan, on the go.
    Nov 27 2010
    mass
    Ah that makes sense. My breather is dumped for now (I barely drive the car so I don't care) eventually I'll do a proper catch can setup.
