Results 1 to 20 of 20
    Veteran Member Three Rings mssurrey's Avatar
    May 29 2012
    Michigan
    question about tire widths for 20x10.5 wheels
    Finally got round to buying my wheels - Niche Targa's 20x10.5 x 27offset. It's time to get some shoes for the...er...shoes.
    Looking through tire manufacturer's technical details (Hankook, Vredestein, etc), most state that 275/30/20 should be fitted only to rims between 9.0 and 10.0 in wide.
    I Know that many here run 275s on 10.5 in with a stretch but my questions are:
    1. does this void the warranty on the tires if something goes wrong?
    2. Can all 275s be stretched onto 10.5 or only certain makes depending of their sidewall stiffness ?
    2013 Audi S5 coupe - Ibis White with Magma Red/black interior.
    Alu Kreutz, H&R OE springs, silver Niche Targa 20x10.5, Stasis Revo Stage 1, RS5 grill, 35% Llumar tints, Xpel Ultimate Clear Bra, Opti-Coat, K&N air filter, S5 mats.
    Next: Not much now other than Rear diffuser and Exhaust.
    Established Member Two Rings Du Werke's Avatar
    Sep 16 2010
    Webster, NY
    No it doesn't void the warranty
    Yes certain brands stretch better than others, but 275 on a 10.5 isn't even stretched in my book and any tire you choose should accommodate.
    Veteran Member Three Rings Izzu's Avatar
    May 06 2013
    California
    I have the exact same wheels with the exact same offset. 275 is barely a stretch, see below. Lowered to 25.75" ground to fender on the front; helps me not rub. 275 will be fine.
    2021 SQ5 - Glacier White
    2018 TTRS - Suzuka Grey (Sold )
    2013 S4 - Monsoon Grey (Sold)
    2012 A5 - Glacier White (Sold)
    Senior Member Two Rings gyoonit's Avatar
    Mar 28 2011
    Los Angeles, CA
    what finish did you get them in? im looking at the silver ones
    gyoonit
    11' S5
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by Du Werke View Post
    Really? I thought for sure you might get some push back if something were to happen. Either way, my shop would cover me in regard to disclosing wheel info.
    Agreed. The PSS "stretch" especially well.
    IMG_0024 by Audiyos, on Flickr
    Sep 28 2013
    UT, USA
    Mops, do you get chips behind your front wheels with your stance being wider than stock? Did you put some clear bra down under your doors to protect the paint?
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by brnt View Post
    I do have clear bra behind all four tires. Will post a pic here is just a sec. Either way, the stone guards would catch most, but I wanted extra protection.
    Sep 28 2010
    NW NC / DE
    Mops on the move
    May 29 2012
    Michigan
    Quote Originally Posted by Izzu View Post
    That's good to see/know. I'm looking at getting the Vredestein Ultrac Sessanta - heard they're really grippy - and I'm gonna be lowered on H&R OE springs (max 1" drop).
    Quote Originally Posted by gyoonit View Post
    Yep - silver here too.
    Do you know if Vredestein Ultrac Sessanta is one of those brands that will stretch easily?
    Veteran Member Four Rings i1overice's Avatar
    May 09 2013
    Loads of junk.
    Northern Virginia
    It will look fine. I have 275s on a 20x11.
    Current - 2017 Honda Civic EX-T
    Sold - 2010 Ibis White S5
    May 29 2012
    Michigan
    Quote Originally Posted by i1overice View Post
    That must be a streeeeeetch...
    Established Member Two Rings rysl31's Avatar
    Dec 12 2013
    Los Angeles, CA
    Dat gloss
    2018 S5 Florett Silver/Magma Interior
    Previous:
    2014 A5 Monsoon Grey Metallic
    H&R Coilovers, AG M590 20x10, Hankook V12 255/30, H&R Spacers, F1 Ceramic Tint 35%, Ecodes, LED Lighting, Xenon-match Fogs, VAG-COM
    Mar 28 2011
    Los Angeles, CA
    Quote Originally Posted by mssurrey View Post
    lets see some pics!?!?!
    gyoonit
    11' S5
    May 29 2012
    Michigan
    Will post when I actually get some tires and mount them
    Speaking of tires - can anyone (gurus?) say which tires run 'wider' for the same size (275-30-20). I'm considering Vredestein but from what I've read they run on the narrower side so that may be a deal breaker.
    Any ideas?
    May 29 2012
    Michigan
    Any Gurus (you know who you are) listening in?
    Sep 28 2010
    NW NC / DE
    I caught that;)
    I really cannot say. I know PSS run wide, V12's run more narrow, and Potenza RE960/Nero M+S are middle of the road. I suggest you look up the specs of the tires you are intested in. Sites such as TireRack allow you to compare, and they list all specs.
    May 29 2012
    Michigan
    I caught that;)
    Thanks Guru. PSS is on the list but wanted other choices of wide tires. The problem is Tire rack etc don't show all tires in that size - eg. they don't have Toyo or Vredestein etc so unfortunately no specs on those tires. Back to the 'ol internet for info.
    Senior Member Three Rings dtronics's Avatar
    Feb 23 2011
    Providence, RI
    You can try calling tirerack too. They have a lot of the information on tire specs available that isn't listed on their site. Give them a call and they should be able to provide you with additional information.
    2014 S5 | Phantom Black | 6MT | Black Optic | Sport Differential | H&R | AWE | HRE | Eurocode
    May 29 2012
    Michigan
    Quote Originally Posted by dtronics View Post
    Now that's Guru-ish info.
    Sorry Guru.
    Sep 28 2010
    NW NC / DE
    285 runs wider in most any selection
