Results 1 to 4 of 4
    Mar 03 2014
    My headlights are on with my DRLs
    I did some coding recently just wondering what I did wrong. When running DRLs my headlights are on as well with the LED strip.
    Veteran Member Four Rings Sgibb16's Avatar
    Jul 02 2012
    2012 A5 & 2002 Passat Wagon
    Fredericksburg, VA
    You have to put the switch to Parking lights I think to get just the DRL's?
    2012 A5 P+ | Sports Package | 6MT | 35% Tint
    REVO Stage II | AWE Quad Exhaust | 034 HFC | E-Codes | FK Silverline Coils | JHM Short Throw Shifter | Eurocode HFIC Pipe | Roc Euro Intake
    TR8 Intercooler | CTS Silicone Hose Kit & Turbo Outlet | CR-15 Strut Brace | Alu Kreuz | S-line Front & Rear Bumper Conversion
    Established Member Two Rings Pop.Tremuloides's Avatar
    May 17 2011
    2005.5 VW Jetta TDI, 93 Jeep YJ
    Colorado
    Not certain what year you have but in the 2013 you can run with DRL's w/o headlights. If you were coding you might have clicked a box or exchanged a "byte" or two. If you are using VagCom/VCDS then do a scan and check under the section dealing with lighting. I messed around with mine a ton a few months ago and seem to recall something about headlights and DRLs but I may be mistaken.
    2013 A5 Premium Plus/Ibis White/Chestnut Brown/Sport Package/MMI Navigation Plus/8AT
    Mar 03 2014
    The switch is on the Parking light.I think I engaged the parking light to turn on as the DRL. found some of the coding associated with it and will try it out. Thank you.
